  E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > New to data logging, please advise
Reply
      05-31-2016, 08:42 AM   #1
Eternal_SIR
Eternal_SIR's Avatar
50
Drives: 2007 335I RWD Coupe
Hey guys, just purchased the MDH Logging feature, figure i'd get some logs to see how my car is performing before doing the actual flash. This is my first time data logging and i used the Auto log feature. Please take a look and let me know if anything it abnormal. Thank you and much appreciated
http://www.datazap.me/u/eternalsir/l...14-15-16-17-22
2007 335i E92 = Injen DCI, ER CP + Tial BOV, BMS OCC, BMS Cowel Filters, Borla Exhaust, Stoptech Sport Brake Kit, VRSF DP, VRSF 5" step IC, custom 25Row oil cooler, MHD Stg 1+ 91 V7.1
      05-31-2016, 11:18 AM   #2
jpsimon
Team Zissou
jpsimon's Avatar
3339
Drives: 2022 M3 Comp - San Marino Blue
FYI: When you're looking at data that skews the shared scale (for instance when some data has really large numbers and at the same time you have other data with much smaller numbers on at the same time) you can click on the line to put that series on it's own axis/scale. It helps make it way more readable
      05-31-2016, 12:25 PM   #3
Eternal_SIR
50
Thanks for the infor. Sorry for my noobness but this is my first time doing datalogging do not too familiar with the software yet (in terms of making the series on its own axis/scale)
      05-31-2016, 08:30 PM   #4
Sgop335
Sgop335's Avatar
Drives: 07 335i e92, 08 535i
Btw that guy jp, think is the founder of datazap
335i e92 TPC 19Ts
      06-01-2016, 12:39 AM   #5
nikitino25
nikitino25's Avatar
Drives: '07 E92 335i
Respekt for sure
      06-01-2016, 09:34 AM   #6
muncie21
Drives: 335ix
Looks pretty normal.
Some thoughts to consider for your next log. Select timing corrections (all cylinders) so you can see if knock is being detected. I also like to look at my Air/Fuel ratio. You select the Lambda tags to see these.
Flash the gal and let's see how she runs.
      06-01-2016, 09:38 AM   #7
jpsimon
Team Zissou
jpsimon's Avatar
3339
that's me!
      06-01-2016, 09:57 AM   #8
Eternal_SIR
50
that's me!
thanks for such an awesome setup.. really appreciate it.
      06-01-2016, 10:00 AM   #9
Eternal_SIR
50
thanks, will do. I don't get much change to have an open stretch to do WOT log. I will select both lambda and log again. Just got my battery charger, was waiting on that before flashing just incase.
Reply
e90post
