Try out the new beta site for E90Post. You can read more about what's happening here
  E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > E90 Door Handle LED's
Reply
      03-20-2012, 05:26 AM   #1
ssc330d
ssc330d's Avatar
England
17
Drives: Le Mans Blue 330d M Sport
Hi all,
new member here. i have just returned to the BMW fold. Recently purchased a 2006 330d M sport. I previously owned a 2005 320d se a car or two ago.
I hope that this is in the right section - I am after some advice about fitting the door handle led's on my 330d. The 2 drivers side ones are fitted and working fine, but the passenger side ones arent working - because there is none fitted!! Please see pic -
After a bit of searching, I know that the part I need is -
My question is - where does the electric cable plug into? Obviously I will need to remove the door trim etc, but has anyone replaced this before and know where the power is sourced from?
Many thanks.
      03-21-2012, 01:43 AM   #2
ssc330d
ssc330d's Avatar
England
17
Nearly 200 views but no reply - obviously not a common diy job!
      03-21-2012, 01:50 AM   #3
1QuikWS6
No 55mph
1QuikWS6's Avatar
1667
Drives: F32 435ix MSport
Just look where they are plugged into on DS, then find a similar loose connector on PS that is not being used - male/female connector types are fairly specific, I can't believe there would be a multitude of the correct style connector hanging around loose inside the door.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      03-21-2012, 10:03 PM   #4
jbimmer3
jbimmer3's Avatar
Drives: E90
They plug in inside the door panel
Car pics HERE
      03-23-2012, 03:43 AM   #5
ssc330d
ssc330d's Avatar
England
17
Thanks for the info. I will take a look this weekend.
Reply
e90post
