BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Paint Code Help
| 09-23-2010, 09:49 PM | #1 |
Some say...
266
Rep 4,296
Drives: Fresh
Paint Code Help
I just had some stuff painted on my car and the color is ever so slightly lighter than the color on my car(alpine white). You can't tell in the sun too much, but in dimmer light it's all I notice. To my understand there are different variations of alpine white, and I know the newer ones have alpine white III. But are there variations of that?? Anyway to tell what the exact paint code of 2007 335i with build date 12/26/06?
![]() I have exhaust and an intake... |
| 09-23-2010, 10:16 PM | #2 |
![]() 34
Rep 210
Look under your hood - the bottom side of your hood near the release/catch - you will see likely 3 sticker. Look at the one on the drivers side of the three - it will list the paint color name "BMW - "Paint Color Name"" and on the bottome of that sticker you will see a 3 or 4 character code like A61/3 - this is your paint code.
| 09-23-2010, 10:50 PM | #3 | |
Some say...
266
Rep 4,296
Drives: Fresh
| 09-23-2010, 11:21 PM | #4 |
NAPAUTO
Rep 16
The correct paint code will not necessarily create a perfect match.
Many paint formulas have variations due to re-batching of the paint at the factory, or slight variations from different assembly plants. A quality body shop will have variation charts, which are paint strips of the color variations. Some whites have five or more variations. These strips will be placed against your existing body panels, and enable a color matching expert to provide the painter with the correct formula for your vehicle. The paint is usually mixed at the auto body shop. I am quite sure that this is the reason that your white does not match. Good Luck! |
| 09-23-2010, 11:35 PM | #5 | |
Some say...
266
Rep 4,296
Drives: Fresh
| 09-24-2010, 03:41 AM | #6 |
No 55mph
1667
Rep 8,499
Primer does affect final color - some mfg. (Porsche comes to mind) actually prime their cars in either black or grey depending on what color was ordered.
Plus, over almost 4 years, don't you think your factory paint has faded/weathered? In addition to all variable factors such as mentioned above, this will also help mismatch. The shop I use has some sort of spectrum analyzer gun thingy that they use to get readings from existing paint - and then it tells them how to alter the mix from paint code to match best. Gun sends readings back to the computer that is mixing the paint.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
| 09-24-2010, 05:52 AM | #7 | |
Some say...
266
Rep 4,296
Drives: Fresh
| Bookmarks |
