BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Adding Subwoofer to basic e90 system
| 07-09-2010, 05:15 AM | #1 |
Rep 15
Hi folks,
My E90 SE came with basic audio system. There is no factory amp, only CD changer. Also I can not see any amp cables mentioned lots of time in this forum. What is the easiest way to install subwoofer in the trunk ? I was hoping to take signal from rear speakers via adapter, use REM from CD changer and thats about it. I can not see how can I get to the rear speakers from the trunk ? Help please... ![]() |
| 07-09-2010, 07:47 AM | #2 | |
![]() ![]() ![]() 2702
Rep 13,236
| 07-09-2010, 05:22 PM | #4 |
aka Mike
115
Rep 1,395
When I did mine, I picked up a signal somewhere in the trunk - worked perfectly. (don't remember, its been so long) Is that because i have the upgraded sound system and the OP doesn't?
| 08-20-2010, 10:34 AM | #5 | |
Rep 1
![]() Hi, I am also going to install a sub and amp on the E90 saloon w/o iDrive. Q1. Will I just vibration if I put a 14" sub in the boot - powered with own amp (no fold down seats). Q2. Where's best location to tap-in to the underseat woofers, what colour are the wires? Q3. Best location for a remote wire? As eliotn, I dont have factory amp - doh! Just sold my Jet Black E46 and got me this E90 baby in Graphite !Thanks |
| 08-27-2010, 01:43 AM | #6 | |
Rep 19
Yellow/Red + pin 14 Yellow/Brown – pin 4 REAR RIGHT WOOFER Blue/Green + pin 13 Blue/Brown – pin 3 They are easy to spot in the harness, they are the 4 bigger wires. Hook them up to a 2-channel line output convertor and you're good to go. From: http://www.e90post.com/forums/showth...t=52193&page=2 http://www.e90post.com/forums/showthread.php?t=138949 My wiring harness had a tiny black wire which I found out was the stock amp's remote wire. I just spliced into that. Worked perfectly. Eliotn: Since you don't have factory amp, you could tap into cigarette lighter wiring, I have heard of other people on hear doing that. This thread may help too http://www.e90post.com/forums/showthread.php?t=163804 It goes over how to do SWS-8 install but the amp info included helps. Last edited by IMissMySTi; 08-27-2010 at 01:48 AM.. |
| 06-16-2019, 09:22 PM | #7 |
Rep 362
What subwoofer and amp is everyone running? I’m have older 12 alpine type with pdx5 amp. 200-300 rms and since my seat doesn’t fold down or have a pass through I can barely hear it. I have a small custom made corner box that I bought off here a few years ago. It’s about 1 cubic foot sealed. What’s should I be looking for?
| 06-17-2019, 09:40 AM | #8 | |
Rep 6,965
Drives: 2007 Black/Black 335i e90
| Bookmarks |
