BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Long Term Effects of Catless Downpipes
| 04-12-2009, 03:34 PM | #1 |
Rep 984
I'm planning on buying either the RR or AR catless downpipes but was wondering if there were any negative long term effects of removing 2 cats? Is the 5-10 hp difference between catted and catless downpipes noticeable?
| 04-12-2009, 03:36 PM | #2 |
![]() ![]() ![]() 769
Rep 10,584
shouldnt be any long terms changes, the turbo's should actually have a little less stress on them.
the increase is noticeable, especially the quicker spool and better throttle response.
| 04-12-2009, 05:39 PM | #3 |
![]() ![]() ![]() ![]() 23
Rep 706
| 04-12-2009, 06:14 PM | #5 |
Rep 1,441
Drives: e92 335i, f10 m5 comp
how about global warming?
| 04-12-2009, 06:49 PM | #7 |
ocasionally in crisis
59
Rep 2,358
had my catless dps on for 1 year = no smell at all.
![]() far as global warming... i plan on quiting smoking within 2 months
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
| 04-12-2009, 06:52 PM | #8 |
![]() 216
Rep 2,486
On a serious note, here in MD, we have to take an emissions test every two years. If you do too, how do you get around it?
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
| 04-12-2009, 07:30 PM | #9 |
314
Rep 4,408
Benjamin is usually a pretty convincing guy
![]() In other news, downpipe long term effects usually include miles of smiles, giggles, and a sudden need for new rear tires ![]()
-Critter
| 04-12-2009, 07:31 PM | #10 | |
![]() 138
Rep 4,764
If they do fail your car they give you time to correct it and bring it back. If you are not throwing any codes, you will be fine: "What is the Right Test for Your Vehicle? On-Board Diagnostics (OBD) Test 1996 or newer model year vehicles weighing 8,500 pounds or less and equipped with a computer controlled engine and fuel system Instead of testing your vehicle’s exhaust, your emissions test will involve scanning your vehicle's computer for emission control malfunctions. During an on-board diagnostics scan, a lane inspector will connect to your vehicle's computer through a connector under the dashboard to determine the presence of recorded “trouble codes” that illuminate the “check engine” light on the instrument panel. Vehicles with an illuminated “check engine” light automatically fail the emissions test." http://www.marylandmva.com/MVAProg/VEIP/veipinfo.htm |
| 04-12-2009, 07:42 PM | #11 | |
Rep 10,584
yeah here in MD you'll be fine most likely running fully catless assuming your not throwing codes. They will just plug into your OBDII, find no codes and your on your way.
| 04-12-2009, 11:53 PM | #12 | |
LINEITUP
62
Rep 725
+1 ..... All my cars ive ran Full Cattless exhaust systems with out any problems or smells. |
| 04-13-2009, 03:37 AM | #13 |
![]() 92
Rep 1,575
This is one of the effects for sure...but it seems that this is Inevitable (but not because of our catless DPs)
The other effect is that your wastegates will live longer.
![]() Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
| 04-13-2009, 11:43 AM | #16 |
![]() 313
Rep 2,576
Well the polar caps are shrinking for sure. He may be referring to the concept that global warming is cyclical and happens regardless of man's contribution. There are many scientists that believe this to be the case and that global warming as a result of man was spawned by politicians.
Regardless of which global warming is happening. |
whyzee1252611.50 |
| 04-13-2009, 12:08 PM | #17 | |
![]() ![]() ![]() 43
Rep 471
- content to not know the answer, but do agree, that regardless of the actual reason, cleaner emissions are good overall.... |
| 04-13-2009, 12:11 PM | #18 |
One cam is enough
142
Rep 6,801
I am here to educate you about the single biggest threat to our planet. You see, there is something out there which threatens our very existence and may be the end to the human race as we know it. I'm talking, of course, about Manbearpig. It is a creature which roams the Earth alone. It is half man, half bear, and half pig. Some people say that Manbearpig isn't real. Well , I'm here to tell you now, Manbearpig is very real, and he most certainly exists—I'm cereal. Manbearpig doesn't care who you are or what you've done. Manbearpig simply wants to get you. I'm super cereal. But have no fear, because I am here to save you. And someday, when the world is rid of Manbearpig, everyone will say, "Thank you Al Gore—you're super awesome!" The end.
And California's answer to manbearpig is to ban black cars. I wonder if any conclusive, impartial research had even been done on their part before diving into this idea. |
| 04-13-2009, 12:36 PM | #20 |
One cam is enough
142
Rep 6,801
| 04-13-2009, 12:59 PM | #21 |
![]() 44
Rep 1,084
DP's are well hidden. You would have to remove the underbody cover to reveal the downpipes. No inspector's going to do that. They're just going to do a visual and see the rear Cats and run the smog test. It should pass as long as you don't throw any codes.
| 04-13-2009, 01:01 PM | #22 |
One cam is enough
142
Rep 6,801
Good point.
| Bookmarks |
