Try out the new beta site for E90Post. You can read more about what's happening here
  E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > What plugs and coils for upgraded turbos?
Reply
      04-17-2020, 02:38 PM   #1
alexwilcox29
Drives: 2009 335i
After tons of research over the last year and non stop research this past month I am kind of stumped with what plugs and coils set up to run!
I am currently fbo without inlets and am prepping my car for upgraded twins (maybe single still undecided)
I am running oem plugs and coils currently and they are at about 20k miles so I figured I'd upgrade them to handle the added power! I haven't had a single misfire issue with my car with this set up at 20psi
There seems to be a lot of different set ups people are running and I'm trying to figure out what would be the best for about 500-575hp running 10+ gallons of e85
It seems like everyone goes 2 steps colder plugs and precision coils but is that really necessary?
I was thinking maybe s55 plugs with precision or bimmer life coils!
Any info or experience with a similar set up/ power level would be awesome! Thank you guys!
Crimson LCI E90 N54 auto - sold
Lemans LCI E92 N55 manual - current
      04-17-2020, 07:09 PM   #2
WoodE30
Capt. Maverick
64
Drives: 89 E30 325is, E92 335i N54
2013 X5 3.5xdrive  [0.00]
1989 325is  [0.00]
2008 335I coupe  [0.00]
I'd recommend eldor coils and N20 plugs gapped to .018-020
I'm running DAW stage 2+ turbos running e50 mix. Runs well with the eldor coils and n20 plugs
      04-17-2020, 07:43 PM   #3
rev210
Drives: 335i 2008
Eldor -stock coils. I am on Pure stage 2 hiflows, car runs 10s , no issues making power. Upgrade spark when it becomes a challenge
      04-17-2020, 09:04 PM   #4
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
As long as you don't go go over 600hp, Eldor Coils are the way to go.
If you have an original DME that's an MSD80, you should proactively change out the 6 mosfets in the DME that control the coils.
Plugs / NKG 2 steps colder gapped at .018
You'd need stage 2 turbos & a stage two LPFP to get to 575hp
      04-18-2020, 10:03 PM   #5
alexwilcox29
Drives: 2009 335i
You're also running stuck plugs as well? That seems like a good game plan! I really have no complaints about the stock ones, they haven't given me any trouble!
      04-18-2020, 10:07 PM   #6
alexwilcox29
Drives: 2009 335i
Good to know coil wise! And my car is an lci e90 '09 I haven't looked at what dme I have but I'll check soon it's handles the jb4, xhp, and mhd bef so far!
I worry about using plugs with that small of a gap just for fuel economy, I have a stage 2 pump but I'm still getting 13mpg and am okay with that for now!
And definitely play for stage 2 turbos or a small single!
      04-19-2020, 10:16 AM   #7
mweisdorfer
2008 bmw x5  [0.00]
The NKG plug is the way to go IMO. You start going over 500hp on stock plugs, I think IMO, you are begging for trouble😐
NKG two steps colder plugs gapped at .018 is the right application for stage 2 turbos fueled by a stage 2 pump using e30 or e50.
You have a MSD081 DME. So, you have no worries with the mosfets.
Look into Rob Beck stage 2 or stage 2+ turbos. Very reasonable priced with no failure rates. He even gives you a $300.00 discount if you pay him by check or cash.
      04-20-2020, 10:54 AM   #8
alexwilcox29
Drives: 2009 335i
Gotcha! Ordered a set of bimmer life coils, we'll see how those do! And I'll get the 2 step colder plugs for that!
I haven't dont much research on rbs but I'll look into them, I was almost thinking of just cheating out and getting like Vargas stage one or two turbos, I know early on they had some issues but seems like it was ironed out since then! But correct me if I'm wrong of course!
      04-20-2020, 12:03 PM   #9
mweisdorfer
2008 bmw x5  [0.00]
Rob Beck has been making turbos for the N54 since people first started tuning it way back in 07'.
There's no substitute for experience. All work is done in house & not farmed out to China, Taiwan & the like.
The top 3 turbo Companies for the n54, at least IMO are;
1) Rob Beck
2) Pure
3) Vargas
Look into where pure & Vargas are made before you make any final decisions.
Wow Bimmerlife coils - you aren't messing around! 😉 You should be good for over 600hp, no question.
Keep in mind, you will have to gap the plugs to .018 once you get them. THEY DO NOT COME PRE-GAPPED
Reply
e90post
