03-19-2020, 09:35 AM | #1 |
Rep 10
BMW S63TU M5 M6 FABWORX downpipes install- Complete DIY
Full instructional Video (Including special tools, parts, torque specs and skill level) on how to replace the downpipes on an M6. Its the same procedure for an M5 and very similar to an N63. Feel free to comment opinions or questions. Special tools: Torque wrench, stubby 6 mm allen and multimeter, E-Torx sockets Parts: Downpipe to exhaust gasket ring- (2) 18307843213 Turbo charger to downpipe gasket ring- (2) Downpipe to exhaust nuts- (4)18307597650 Torque specs: Turbo to downpipe V-band-19mn Downpipe to exhaust nuts- 21nm. Skill level: (1 easiest, 5 hardest) 2 Fernando Osorio President Milestone Motors LLC Website: https://www.milestonemotorspb.com/ Instagram: https://www.instagram.com/milestonemotors/ Facebook: https://www.facebook.com/Milestonemotorspb Email: milestonemotorsllc@gmail.com Linktree: https://linktr.ee/milestonemotors Snapchat: Milestonemotors Fabworx downpipes can be found here: http://fabworxperformance.com/produc...ownpipes-2012/ |
03-19-2020, 04:03 PM | #2 |
Rep 582
Nice job ! but you didn't show how to reinstall the 2 gaskets underneath on the downpipes and whats the torque value of the copper nuts that hold the mid pipe to the downpipe bracket.Ok I see the values in your list
Like you said I did mine with the DMEs in place bungee cords holding them open to the hood shocks worked great ,I didn't remove the PCV valves or the power steering reservoir,I was scared to remove the DMEs lol,looked like so many plugs That was a good idea for the heat shield,I ran into that problem but I just cut the bottom of the cup off and reinstalled it just to look like its in there threaded the 02 sensor directly into the downpipe , I might get a turbo blanket for that spot anyway Those bottom nuts I didn't know the torque value,so to compress the new gasket it feels like its getting tight and I was nervous I would snap one of the studs ,but I kept going equal on each side until they were snug you can feel them bottom out < i will retorque them when I change my oil next time I never changed the gaskets in the turbo housing ,I didn't even know they were there ,I guess they just pop out and press new ones in there?? You didn't put the part number for these Thanks for the vid Im sure it will help the DIY guy Can you make a step by step vid on how to change the coil packs and spark plugs ? Thanks
03-19-2020, 04:33 PM | #3 |
Rep 10
Hi Whipple! Yes, When I worked at the dealer there were people who would leave the DME's in, Both ways work. If you take DME's out its a bit more comfortable.
I will provide those part #'s tomorrow! Yes, they slide out easily- with a hand pick you can pull them out and pop the new ones in. |
Whipple262.50 |
03-19-2020, 06:05 PM | #6 | |
Rep 582
Thanks you |
03-19-2020, 06:58 PM | #7 |
Rep 10
Keep the ideas coming! I'm all about taking instructional videos, I recently changed my niche at the shop to only servicing BMW's & MINI's so ill have a lot more time to shoot and edit.
03-20-2020, 07:45 PM | #8 | |
Rep 98
Part #18307553601 https://www.realoem.com/bmw/enUS/sho...diagId=18_0952 |
03-21-2020, 09:15 AM | #10 |
2016 M6CP/Vorsteiner Aero/DME S3/Fabworx DP
22
Rep 131
This is my car he installed the downpipes on! Great Job & Great Price Located in South FL!
TinCanSailor735.00 |
11-21-2021, 09:29 AM | #13 |
Fueled by Recycled Dinosaurs!
735
Rep 1,237
Drives: F06 M6
Could someone kindly confirm that these two gaskets are the proper numbers for downpipe install.
18307553601 18307843213 Searches at various stores online either don't have it listed or claim fitment cannot be guaranteed. Thanks in advance.
11-21-2021, 10:16 AM | #14 |
Rep 642
you should be able to reuse 18307553601. 18307843213 is the correct part number for the downpipe outlet (connection to the rest of the exhaust)
F06 M6 Grand Coupe CP
11-21-2021, 11:17 AM | #15 |
735
Rep 1,237
Drives: F06 M6
Thank you clarification on the part reuse and the part number for reorder.
11-22-2021, 01:56 AM | #16 |
Rep 98
11-22-2021, 11:29 AM | #17 |
735
Rep 1,237
Drives: F06 M6
yeah, good point. Why risk the re-work over a few bucks.
Tags |
bmw, downpipe, downpipes, exhaust, f06, f10, fabworx, s63tu |
