07-04-2021, 01:12 PM | #1 |
Rep 84
Can’t clear codes 2015 F12
Hi,
My passenger side door window in inop. Scanned car with BimmerLink. Cleared all codes, cleared memory, and cleared permanent codes. 2 codes keep appearing and are active. Central gateway module 801C20 Central fault memory full. Error present and stored. Drivers side footwell module. 030095 Fh NG:invalid characteristics, no standardization available. Error present and stored. What can I do about these faults? Thanks in advance. |
07-06-2021, 03:54 PM | #2 | |
Rep 84
Was hoping for some information. Is there a better place to post this question? |
07-06-2021, 04:50 PM | #3 | |
Rep 642
The task assigned to this subfunction is the central storage of Check Control messages, in addition to local fault memory units on individual control units. The Central Gateway Module (ZGM) is the master for this function and is also known as the diagnosis master.
F06 M6 Grand Coupe CP
07-06-2021, 09:51 PM | #4 | |
Rep 84
09-05-2024, 09:53 PM | #5 |
Rep 5
OP it looks like you never received a response here unfortunately.
As it has been several years I assume you would have solved the issue...? Could you please share how you ended up repairing as I am now having the same problem with my 2014 F12 TIA |
