Try out the new beta site for E90Post. You can read more about what's happening here
  E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Wastegate rattle fix redneck style
Reply
      07-10-2015, 03:58 PM   #133
AtlasDoc
Drives: '07 Monaco Blue 335i
This update will eliminate deceleration rattle, but not acceleration rattle.
      10-29-2015, 09:02 PM   #134
puppydax
puppydax's Avatar
Drives: '25 Portimao M2
How is everyone's still holding up? I've learned to deal with my actuator rod rattling, but it would be a convenience to have a BMW that doesn't make tinny noises. My wastegates aren't rattling and I can clearly see the oblonged area of the actuator rod that is causing the rattle.
https://www.instagram.com/puppydax/
Previous:
2007 E90 335i | 2008 E92 335i | 2009 E82 135i
Current:
'25 ///M2 Portimao Blue
      01-30-2016, 06:17 PM   #135
thenewrick
Drives: 2007 E93 335i Black Sapphire
So I've had the wastegate rattle both accel and deccel. I did the spring fix and it did helps with the deccel rattle quite a bit but now I get an Engine Malfunction reduced power signal when I get higher in the RPM range and boost around 5k rpm. I also noticed my power output is less all around too.
I'm torn because I love that it makes less rattling but it kills me to have essentially stock power and get these error signals when I get on the throttle.
Anyone with experience in my shoes have any ideas. Any input?
I'm thinking of just taking the spring off and dealing with the rattle . I miss the silly high power. BOOST!
      01-30-2016, 06:26 PM   #136
kiteboy
kiteboy's Avatar
France
15
Drives: E92 Stage 2 BR Performance
Same issue for mee @ 117 000km
Verdict both turbo replaced !!!
Now 167 000km and ras a little bit rattle just after 3000rpm on decel, but my car had already do this i don't know why exactly ???
      06-01-2016, 08:28 AM   #137
Mattdrake27
Drives: 08 335xi
I have brand new stock replacement turbos with the upgraded wastegate components and the car was rattling like crazy. I went into the JB4 FUD options (click on the "bits" tab under user adjustments) and there was an option for "alternative wastegate position" which set the FUD to 128. I went to setting 10 on the speedo and set the RPM setting to 5 and the rattle is gone. Boost response is great too.
I think the jb4 settings just needed to be tweaked.
Reply
e90post
