BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Wastegate rattle fix redneck style
| 05-09-2014, 03:03 PM | #111 | |
Rep 689
Post up and let me know if you find a gasket or washer solution.
Nick | 2011 Competition Package M3 Sedan | @Restoration_Motorsport on IG
| 05-14-2014, 09:28 PM | #112 | |
![]() 8
Rep 141
![]() I'm movin to TX on monday, Ima order me 2 of em after I get settled in
2007 BMW 335i- stockish for now.. ZHP shifter, VRSF DPs, JB4..
2009 Chevy Cobalt SS- bolt-ons, 18/26psi tune: Easy M3 Killer [SOLD] |
| 05-17-2014, 10:35 PM | #113 |
![]() 301
Rep 1,834
Drives: 08 E90 335xi TiAg
Would love to know if the Audi/VW clip worked as well. My dear arm has play. Turbos are 5k miles new from dealer. Ugh.
| 05-19-2014, 01:36 PM | #114 |
![]() 0
Rep 96
Drives: e92 n54 LSD....
| 05-20-2014, 08:57 AM | #115 |
Rep 380
Just FYI I couldn't find anything this weekend I think I want to try the fix where you tighten the bolt but I'm curious how long that fixes the issue before rattle comes back.
| 05-20-2014, 10:58 AM | #116 |
![]() 8
Rep 141
You have to be careful when you tighten the arm on the actuator, I over tightened mine(got no rattle! Lol) an threw a 30ff code, loosened it up an still threw it til I put it back to where it was
| 05-20-2014, 02:44 PM | #117 |
Rep 515
I have adjusted the bolt until I got no rattle, for about 20k miles now. However as of last week, I am experiencing extreme rattle again and my exhaust note is different, and I am unable to boost at times. Related or not I am unsure yet.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
| 05-20-2014, 06:45 PM | #118 |
![]() 223
Rep 2,800
For anyone who has new stock turbos and has rattle, check this thread out, it helped me out. My logs looked like his "before" log in post #15.
http://www.n54tech.com/forums/showthread.php?t=16184
![]() thanks to MGallop |
| 06-01-2014, 07:49 PM | #120 |
![]() 9
Rep 55
Found a much cheaper source for the Audi clips at $19~ shipped. Unfortunately Aliexpress no longer ships to WA state.
http://www.aliexpress.com/item/2-0T-...605206426.html |
| 04-30-2015, 10:54 AM | #121 | |
Rep 148
Sorry to dig up an old thread, but did this clip end up helping to get rid of the rattle?
E82 AW /ATM FMIC/VRSF DP/ER CP/TialQ/CobbV2/Koni Yellow/M3 Sway Bar/Roc Euro DCI/Berk Street/
| 04-30-2015, 11:23 AM | #122 |
![]() 319
Rep 516
Impretty sure there as an extended turbo warranty for the rattle issue. If you have it they will replace your turbos. Not a recall but the next best thing to get new turbos, as long as you can show you have the rattle.
Also the rattle comes from many areas. The worst is the flapper valve being to close to the seat and too loose on decel, which is why the JB4 tune adjusts for it and fixes it in many cases. Other contributing factors is the wear of the bushing in the exhaust housing for the flapper valve which if its pretty worn the flapper valve shaft will rattle inside the housing in that bushing area. Another is how loose the WG actuator shaft is on the flapper valve arm outside the turbo held on by an E clip. |
| 04-30-2015, 12:54 PM | #123 | |
Rep 148
| 05-24-2015, 06:07 PM | #124 |
![]() 870
Rep 2,786
I've had terrible wastegate rattle from my rear turbo for the last 5 months, car has 112xxx miles and been tuned with the JB4 G5 since around 75k. Problem just reared it's ugly had this winter. I used the JB4 menu to adjust the settings of the wastegates and while it helped some with the rattle the trade off in lag wasn't really worth it. So I finally got around to trying this JUST NOW and the rattle is pretty much gone. I even reset the wastegates to their original settings and it's sounds like stock again. Best $2.75 I've ever spent... thanks OP.
I'll update in a week or so to tell everyone how this is holding up. |
| 05-25-2015, 09:58 PM | #126 |
![]() ![]() ![]() ![]() 241
Rep 703
The new version on JB4 eliminates the rattle, I had the worst one and it's all gone now!
On e FUD you'd have to put in 98 though!
ESS G1 e90
- BBS E88 |
| 05-30-2015, 05:35 AM | #127 |
9314
Rep 11,242
Are you referring to the latest JB4 update? Did you have the rattle during deceleration?
| 05-30-2015, 05:37 AM | #128 |
Rep 703
Yes the newest update, no rattling issues at all. My friends thought I got new turbos cause I would always complain I had the worst rattling. When installing the new software on FUD4 type 98 and then on the speedo go to 10 (100) and on the rpm side set t all the way to 5k.
ESS G1 e90
- BBS E88 |
| 05-30-2015, 05:41 AM | #129 | |
9314
Rep 11,242
| 05-30-2015, 05:42 AM | #130 | ||
Rep 703
ESS G1 e90
- BBS E88 |
| 05-30-2015, 05:44 AM | #131 | |
9314
Rep 11,242
| Bookmarks |
