Try out the new beta site for E90Post. You can read more about what's happening here
  E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Wastegate rattle fix redneck style
Reply
      05-30-2013, 09:56 AM   #89
._.
I took it off mine because I was not getting boost either, with it on after the first 3rd gear pull I was only getting 7-8 psi when it should have been 15-16 psi. Removed it and all is well. I think the spring slid down near the wastegate and blocked full motion of the actuator arm.
      05-30-2013, 11:54 AM   #90
elig0nzal3z
Drives: 2007 335i
2007 bmw 335i  [0.00]
yea i feel like this will only help those whos rod itself is the problem but for others who hits the actual flap not closing properly with wont do us any good.
      05-30-2013, 12:05 PM   #91
takrdown
Other car was a submarine
takrdown's Avatar
113
Drives: i4M50 (waiting), 2013 R56 JCW
Very interested to see if the VW/AUDI spring clip will work/fit.
Let us know!!!
      07-03-2013, 03:35 PM   #92
medvec04
Drives: 07 silver 335i sedan
Did mine today works great
      07-03-2013, 03:36 PM   #93
kiteboy
kiteboy's Avatar
France
15
Drives: E92 Stage 2 BR Performance
Where it is possible to order it ?
      07-03-2013, 04:28 PM   #94
takrdown
takrdown's Avatar
113
Anyone try the VW clip?
      07-03-2013, 05:12 PM   #95
medvec04
You don't have a ace hardware or home improvement store near u
      08-10-2013, 10:18 PM   #96
scorpnaz7
Drives: 335i
Has anyone had any negative side effects to this?
      04-09-2014, 08:37 AM   #97
Glopez5
Glopez5's Avatar
Honduras
19
Drives: E92 335i
curious if anyone has tried this since last year? or any updates from those that tried this?
07 E92 335i -BSM- Sport- iDrive- Premium- Cold Weather- Aero Lip- M3 Trunk Lip- Injen Dual Cone- Posi Quiet Ceramic Pads- R1 Premium Cross Drilled Rotors- H&R Sport -JB4+Ethonal- - Raceland DPs - Avant Garde M310- Alpine TypeR 10''- Alpine MRP-M500 Amp
      04-09-2014, 02:24 PM   #98
thompsac25
Stance to make her dance
thompsac25's Avatar
886
Drives: 2023 G80 M3
Tried it last night. Did not solve any of my rattling issues.
INSTAGRAM: thompsac_m3 YouTube: ACCELERATED MOTION
2023 G80 CX M3, Individual BRG
      04-09-2014, 02:29 PM   #99
iturbo_bmw
iturbo_bmw's Avatar
Drives: 335i, 530i
aw wow i read through this thinking it was a new solution
      04-10-2014, 09:26 PM   #100
Mr.Mastashake
Mr.Mastashake's Avatar
Drives: 07 335i
Anybody ever try one of those VW clips? They're $41 from ECStuning, I might be able to reach the front turbo actuator from under the car, but its worth trying on the rear one
2007 BMW 335i- stockish for now.. ZHP shifter, VRSF DPs, JB4..
2009 Chevy Cobalt SS- bolt-ons, 18/26psi tune: Easy M3 Killer [SOLD]
      04-14-2014, 07:35 PM   #101
M-powered
Drives: 2007 e92 335i
I have invented a new approach!!!!
I found some play in the hinge that leads into the valve, i decided to take up the slack by inserting a "gasket". The pictures should help clarify. This finally helped the noise be reduced by 80%[IMG][/IMG][IMG][/IMG]
      04-14-2014, 08:01 PM   #102
Glopez5
Glopez5's Avatar
Honduras
19
Drives: E92 335i
Interesting, where did you find those gaskets? i'll have to get under the car next weekend and play with it.
      04-15-2014, 06:56 PM   #103
M-powered
those are metal gaskets from an old engine, i cut them in a way so they slide in and self clamp, NOTE!!! (its very important to flatten the metal gasket by hitting it with a hammer because if you don't the gasket will be too snug and may prevent the actuator from moving the lever back and forth.)!!!! look closely at the picture and you will see how wide the opening has to be.(about the thickness of a bmw key.) I was able to reach the front turbo one as well by using a very long needle nose plier and just slid it in.
      04-30-2014, 06:18 PM   #104
datbimmer
Wastegate Rattle
Drives: 335i m6t nav sport
I just went outside to check and sure enough the rod seems to be loose. I will try this later tonight.
      04-30-2014, 07:56 PM   #105
datbimmer
Wastegate Rattle
Update : Spring didn't help it at all. 0. I even tried using more pressure. Still nothing. I only checked the startup rattle, didn't bother going around to try it.
      05-03-2014, 07:55 PM   #106
ironviet
Drives: 2017 F80 M3 ZCP
2018 Jeep Wrangler ...  [0.00]
2017 BMW M3  [0.00]
2007 BMW 335i  [0.00]
2004 BMW M3  [0.00]
Curious to know if anyone has tried the VW clips and if it worked
      05-03-2014, 09:37 PM   #107
CptJoe732
CptJoe732's Avatar
26
Drives: 2007 E90 N54
Yea me too. I really dont think it will work but if someone says its a solution il spend 40$ on it.
      05-04-2014, 06:07 PM   #108
Motorsport.Nick
Motorsport.Nick's Avatar
Drives: M Sedans
I tried the spring method on the rear turbo this morning. It might have helped reduce the rattle by a tiny tiny bit but it was not a solution for me.
Disappointing for sure, thought I think something along the lines of what M-powered did will work better for me.
When I was wiggling the arm around with my hand I could feel the play, which seemed to be coming from where the waste gate arm extends out of the body of the turbo.
M-powered, where could I find a gasket like what you used?
Nick | 2011 Competition Package M3 Sedan | @Restoration_Motorsport on IG
      05-04-2014, 07:59 PM   #109
tooch
Drives: F82
Thats a good idea.
96 E31 JB
07 E92 AW
F82 BSM
      05-09-2014, 07:34 AM   #110
Glopez5
Glopez5's Avatar
Honduras
19
Drives: E92 335i
+1 mine i can wiggle that area with my fingers so i'm assuming a washer or maybe that gasket could solve my rattle
I have off next week on vaca maybe i'll tinker with a gasket, but i'm not sure where to find a gasket small enough.
Reply
e90post
