BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
VRSF Outlets O-ring Help
| 12-07-2018, 09:49 AM | #46 |
Rep 1,551
There really is no need for an o-ring that can handle that much heat, up to 1200 degrees. The outlet is not connected on the exhaust side of the turbo, where the real heat is. Understood that some heat will transfer, but if it is enough to worry about melting the o-ring, no IC would be capable of dropping the temp down to the levels required on the incoming air. As mifesto mentioned, a 400 degree one should be sufficient.
feuer4346.00 |
| 12-11-2018, 09:51 AM | #47 |
![]() 27
Rep 142
I haven't torn apart my car until I know the o-ring will work. no I have not tried OEM o-ring (since my car isn't apart yet). so far I've been unsuccessful in sourcing a local vendor with o-ring at appropriate temperate range.
| 01-25-2019, 03:32 PM | #48 |
![]() 38
Rep 231
Looks like I have the same issue, had my installer install these outlets and my PS2. During our test drive, we found a boost leak and this awful sound. We checked all the basic sources but it wasn't until he saw this thread that we knew what the problem was. Here is an example of the sound I was getting under boost. Now i have to wait for a respond from VRSF/N54tuning and pay my installer to re-do the work.
PM Tiago & Mike@N54tunning to hopefully get my replacement expedited. |
| 01-25-2019, 06:25 PM | #49 |
![]() 13
Rep 64
I installed these outlets recently and I'll be blunt. The design of these at the compressor housing is bad... bad for both flow and sealing. The o-ring face seal design sucks (or should I say blows like a boost leak
) compared to the factory radial o-ring seal and is much harder to install correctly and more prone to shifting and losing seal down the road.On top of that this face seal design creates a hard 90 degree step in the compressor housing going from about 1" diameter to around 1.5" which is terrible for flow. I actually machined some aluminum "nozzles" that fit into the compressor housing step in an attempt to create a smoother transition to the larger outlet inner diameter. |
| 01-26-2019, 02:53 AM | #50 | ||||
2142
Rep 43,349
![]() Quote:
![]() Quote:
Please remember that these are pressurized applications and the increase in overall air flow significantly outweighs smaller diameter tubing ![]() Last edited by Tiago@VRSF; 01-26-2019 at 03:57 AM.. |
| 01-29-2019, 06:59 PM | #51 | |
![]() 13
Rep 64
Regarding flow, claiming that an abrupt 1" to 1.5" 90 degree transition flows the same as a smooth and gradual transition contradicts everything I know about fluid flow and suggests airplanes should be shaped like flights of stairs or downpipes should have square 90 degree transitions in diameter. If you did test this can you post dyno charts and specifics about the geometries tested? Also, flow testing numbers from OEM and aftermarket outlets tells a very small part of the story and only supports the obvious that larger tubing flows more. To be more accurate you would flow test the outlet with compressor housing. If you did this my money is on seeing higher flow by adding a transitional nozzle where the step in the compressor is. Anyway, not trying to attack your product by any means and think it's hard to beat for the price, just offering some observations from an engineer that's been modding cars for decades and hoping maybe someday you'll come out with a version 2 that's even better |
Rob@RBTurbo391.50 |
| 01-29-2019, 07:52 PM | #52 | |
2142
Rep 43,349
In either case I'll take a look at our shop car's aftermarket turbo setup and compare them with a few of our client's ID to see if we can improve upon the design ![]() Last edited by Tiago@VRSF; 01-30-2019 at 12:37 PM.. |
| 01-30-2019, 09:31 AM | #53 | |
Rep 1,571
But that aside you sir have knocked it out of the park with this reply, kudos to you for sharing your insight. Not many around here these days have the knowledge that you clearly do, and the community needs more like yourself to shed light on these sorts of things to educate others and to grow the platform. Keep up the good work. ![]() Rob |
| 01-31-2019, 06:22 PM | #54 | |
![]() 13
Rep 64
Appreciate your openness to public feedback and understand your position of wanting the most universal solution for the outlet flange. I may be in the minority for wanting upgraded outlets for stock frame compressor housings and the negatives I pointed out of course don't apply to larger housings that don't have the step for stock outlets. |
| 01-31-2019, 06:25 PM | #55 | |
![]() 13
Rep 64
![]() Phil |
| 02-01-2019, 01:46 PM | #56 | |
![]() 38
Rep 231
| 02-19-2019, 09:44 PM | #57 |
AW E92
27
Rep 93
Any update here? I am waiting to install my outlets but haven't heard any word on the correct o-rings to use. Has anyone had luck installing these outlets? Any o-rings on the market that will fit?
![]() Tiago@VRSF have you had a chance to find any suitable o-rings? |
| 03-13-2019, 02:11 PM | #58 |
![]() 38
Rep 231
Tiago sent out the o-rings after several back and forth emails. I got them installed and it resolved my issue. Needless to say, this o-ring issue caused me hours of troubleshooting and an extra $400 for re-installation fee.
![]() Here is the old o-ring on the left and new on the right. |
| 03-13-2019, 09:42 PM | #59 | |
AW E92
27
Rep 93
| 03-13-2019, 10:13 PM | #60 | |
![]() ![]() ![]() 134
Rep 573
I was promised new orings by Tiago@VRSF and got a tracking number but they never got shipped. Now that it's getting warmer and i'm taking the car out more i hear a whoosh noise on the rear turbo area when boosting and i'm going to guess it's the O-ring Last edited by Supra2k6; 03-13-2019 at 10:18 PM.. |
| 03-14-2019, 12:32 AM | #61 |
2142
Rep 43,349
Thanks again for your patience folks. If anyone hasn't received their replacement o-rings, please forward over your order number via PM so we can get you squared away
| 03-15-2019, 12:40 PM | #62 | |
![]() 38
Rep 231
| 03-28-2019, 10:15 AM | #63 | |
Rep 573
LOL that is the exact noise my car makes (no codes) either i thought i was a pcv valve going bad it drove fine after install and then the noise came a few weeks later didn't (it's winter so i hardly drive the car) Thank you anybody had any luck getting o-rings from vrsf? still waiting on mine for a few months now. Tiago@VRSF |
| 03-28-2019, 04:37 PM | #64 | |
![]() 38
Rep 231
| 03-29-2019, 11:03 AM | #65 |
AW E92
27
Rep 93
| 03-29-2019, 11:18 AM | #66 | |
Rep 573
I quoted our last convo with my order number from months ago to him two weeks ago haven't heard back, to be fair i should email or call but car is not going anywhere anytime soon so hopefully he sees this thread soon Tiago@VRSF and yeah i wouldn't start without the o-rings in hand this is a install you do not want to do twice almost as bad as inlets. |
| Bookmarks |
