  E90Post
Jacob.falkmfg
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Wastegate rattle fix redneck style
Reply
      05-20-2013, 01:19 PM   #1
musseilm
musseilm's Avatar
39
Drives: F82 Mineral Gray
The rattle was driving me crazy.. tried the new g5 firmware 20 and 20D but at any lag setting there was some rattle.
Looked around on the internet and seems like on the VW turbos they use a clip on the linkage to reduce the rattle. So i went to Ace Hardware and got myself a #61 spring for $2.10. Hooked it between the arm and heat-shield. Its a very light tension so it should be fine.
Seems like my rattle is reduced 80% still have some but i think it coming from the front turbo.
      05-20-2013, 01:24 PM   #2
pwr hungry
Drives: 335
I may just have to try this, as a temporary fix.
      05-20-2013, 05:19 PM   #3
blackshan
Drives: 2008 AW 335i Coupe
Lmao!! That's a first that I've seen in this community. I bet u won't be the last!
JB4/MHD, Stage 2 lpf,3.5 tmap, AFE DCI AND SCOOPS, ETS 7" Intercooler, AR Catted Downpipes, MMP Inlets,CP-E Exhaust, Carbon FIber CSL Style Trunk lid, M3 Side Skirts, Mtech front lip spoiler, Mtech rear bumper w/carbon diffuser and Alloy Technic 19" matte black rims.
      05-20-2013, 05:29 PM   #4
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
I'm not sure what's more sad. That is has to come down to this or that it actually worked (BMW look what we have to do to your cars!!!)
Eitherway, good luck with it!
      05-20-2013, 05:32 PM   #5
ken1137
ken1137's Avatar
Drives: BMW S1000XR
2009 e90 335i  [6.40]
Your dealer will say your turbo is modified so warranty is denied.
BMWCCA member
      05-20-2013, 05:45 PM   #6
Lux3m35i
Lux3m35i's Avatar
Luxembourg
16
Drives: E92 335i Coupe
It isn't the rod itself which does produce the rattle sound but it's due to the wastegate which does not seal properly?
      05-20-2013, 06:22 PM   #7
pwr hungry
Drives: 335
Not always. The point where the actuator rod mates with the flapper lever gets worn out and goes from being a circular hole to an oval...making the rod end rattle like hell on the flapper lever arm.
      05-20-2013, 07:09 PM   #8
musseilm
musseilm's Avatar
39
Drove the car again tonight and it seems way better. Just a little bit around 3k rpm. Im gonna see if i can do the front one the same way.
Seems like the only solution next to RB turbos
      05-20-2013, 07:11 PM   #9
tofu-
Drives: 335i Jet Black/Coral Red
suddenly... ace hardwares around the country run out of springs
      05-20-2013, 07:14 PM   #10
idriveslo2
Drives: 335i
the issue is the JB4. I am as big an advocate as any of terry and his products, but the fact this went undressed for so long was ridiculous.
      05-20-2013, 07:17 PM   #11
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Nice job! It may not be pretty but you have to admit there's a bit of genius in it.
      05-20-2013, 07:17 PM   #12
tofu-
some rattles are legitimately worn wastegates
but i agree, the problem with the jb4 was ignored until his iso thread on n54tech got lit up
      05-20-2013, 07:19 PM   #13
tofu-
i might give this a try. i don't know what a #61 spring is (and google isn't helping), so i may just pick up something like this http://www.homedepot.com/p/t/1001420...N#.UZq9Um2NDHw
      05-20-2013, 07:23 PM   #14
tofu-
how does this work? http://www.ecstuning.com/Volkswagen-....0T/ES2210978/
      05-20-2013, 07:23 PM   #15
musseilm
musseilm's Avatar
39
#61 is the spring stock number in the store. You will see when you get there.
      05-20-2013, 07:28 PM   #16
tofu-
ah ok
do you remember the dimensions by any chance so i can just order a couple on amazon?
      05-20-2013, 10:34 PM   #17
blackshan
Lol
      05-20-2013, 11:07 PM   #18
robc1976
DIYER
robc1976's Avatar
727
Drives: E90 335i
no, it is caused by poor wastegate rattle design of BMW...if this was "just" tune related RB's would rattle bad also.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      05-20-2013, 11:11 PM   #19
tennis_pr0
Drives: 2--7 BMW 335i coupe
Another wastegate thread. I don't understand that so so so many people have problems with their turbos or wastegates and bmw does no have a recall on this. How can this be? Clearly, their turbos have a defective part on it, so this should be a recall. What am I missing?
      05-20-2013, 11:13 PM   #20
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Recalls are generally only enacted when there's a safety concern.
      05-20-2013, 11:17 PM   #21
tennis_pr0
I understand about the safety. I mean this just seems so unfair to the consumers because obviously these turbos have a defective part on it (it's safe to say that when this many people are experiencing the same exact problem) and bmw should replaxe these with better ones. Turbos are not suppose to have these issues, especially early on, so bmw should just step up and recall these darn turbos. Their customers are spending 60k dollars on their cars and the turbos are crap.
      05-20-2013, 11:52 PM   #22
AtlasDoc
Drives: '07 Monaco Blue 335i
I'd like to try this. Was it easy to get to the rear turbo? Did you have to take any parts off the car to get to it? Thanks
Reply
e90post
