F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) > Jack For Lowered Cars
proTUNING Freaks
      04-22-2024, 06:37 PM   #1
Marcoose
Marcoose's Avatar
Drives: 2016 sDrive35is
Could somebody that actually owns a jack that works well with lowered cars please recommend a jack to buy ? I don't want to work under the car. Just high enough to change wheels at home. And bonus points for something small, compact. Thanks.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
      04-22-2024, 07:26 PM   #2
NWH83
Drives: 2018 F80 ZCP
If you're looking for something to just swap out wheels, check out the Daytona 1.5 ton low profile/low weight (only 36lbs) from harbor freight. (I know HF doesn't have the greatest reputation but the daytona jacks are pretty good, at least in my experience).
https://www.harborfreight.com/15-ton...ump-58811.html
yousefnjr6218.00
      04-22-2024, 07:55 PM   #3
jessejericho
Drives: 2024 M2 6MT
I bought this CAT 3-ton low-profile jack from a local place called Princess Auto, paid $299 CAD for it. It is long and low enough to get to the front and rear center jack points on my M2, at stock height. Would probably need to put a couple of wood boards down to get the car up a bit if it was lowered.
https://www.catpremiumproducts.com/p...ift-floor-jack
Very heavy, really well built. It is my first floor jack so I'm not an expert by any means.
      04-22-2024, 07:57 PM   #4
No one
Drives: F21 118i
My car has M-Sport suspension lowered 10 mm compared to basic. That makes 135 mm of ground clearance as I recall.
I started with this OEM kit: https://www.m3post.com/forums/showthread.php?t=1840053. It turned out a complete piece of shit (this may be why they don't offer it any longer). The jack, in particular, withstood only a few (it looks like 4!) seasonal wheel changes (no overloads!): the plastic bushing gave up (when lowering the car after the last wheel was changed ).
So I bought PITTSBURGH AUTOMOTIVE 1.5 Ton Low-Profile Aluminum Racing Floor Jack, 60569 (min. height 3-1/2", max. height 14-1/8") in 2015 and I am using it since, twice a year. I am very happy with it.
      04-23-2024, 06:58 AM   #5
ttaidapos
Drives: Alfa Romeo Stelvio QV, M2 G87
I got this. I picked it up for a lot more couple years back. It's 275 now.
JEGS Professional Low-Profile 3-Ton Aluminum Floor Jack | 3 ½ Inch Minimum Saddle Height | Lightweight Construction | 360 Degree Rotating Saddle
https://a.co/d/aWLNSsM
      04-23-2024, 08:40 AM   #6
1and1
Loves me some MHD!
1and1's Avatar
Drives: faster than he should...
'09 135i  [10.00]
Fan of the long reach low profile jack, it's nice to reach the center jack points easily
however, the one I have is neither light nor small....
https://www.harborfreight.com/automo...ack-64781.html
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
. . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's
X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg
      04-23-2024, 08:59 AM   #7
chris3g
Drives: 2023 M3 xdrive
i also use the daytona long reach and i recommend it, but if all you want to do is lift one corner at a time, high enough to change wheels you don't need that. you also don't need the $300 ultra-low profile model, i would just get the regular aluminum low-profile daytona model for ~ $130, it's low enough and it's also only 32 lbs. this one https://www.harborfreight.com/automo...ump-58206.html
      04-23-2024, 09:12 AM   #8
chefwong
Drives: X5
If anyone in the Tri State NY area is interested in a AC Hydraulic DK13HLQ, I one one new FS.
That Harbor Freight Bruzenhoil style aluminum jack is nice - maybe for jack points - not sure if it's low and long enough to reach the center jack point on lowered car
      04-23-2024, 09:19 AM   #9
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
I guess it depends on your exact car. To reach my center point on my lowered E92 with a lip, I need to bring the car on low profile ramps then jack the front side point with another jack to then reach the central jack point. And that's why my low profile long reach jack.
But yeah as someone mentioned, depends on how you want to do this. Jack one corner at a time? Or do it "properly" with jack stands one axle or all 4 at a time?
      04-23-2024, 09:31 AM   #10
noemon
Drives: BMW M5
Lift from the rear, place axle stand on the front. Then repeat same for the rear.
Can't have all 4 axle stands at the same time but no need for any ramps or other accessories.
So you work at the front and then move to the rear.
I've been contemplating getting ramps and an extra jack but all in it worked out around £400 + 1 week to deliver and my Intrax 1k2 has just arrived so sod it, I'll do it with what I got.
      04-23-2024, 10:16 AM   #11
///MPhatic
The Seeker
///MPhatic's Avatar
14136
Drives: OG M2 • Exige
I use this one, but got it for $199 on sale. Not sure I'd pay $324 for it.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      04-23-2024, 07:06 PM   #12
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
2012 BMW 335i  [5.25]
2012 BMW 335is  [5.00]
2008 Infiniti QX56  [0.00]
1967 Chevrolet Corv ...  [10.00]
2001 M Roadster  [10.00]
2022 BMW 540i  [0.75]
2009 528i  [9.50]
I have a couple of lowered cars, including a stock 335is. This is the one that works for me:
https://www.harborfreight.com/3-ton-...ack-64781.html
      04-23-2024, 08:50 PM   #13
Marcoose
Marcoose's Avatar
Thank you very much, All.
Does anybody own a compact jack that would fit a lowered car ? Like a scissor model ?
Thanks again.
      04-24-2024, 12:36 PM   #14
BlkGS
BlkGS's Avatar
1353
Drives: BMW X5 M50i
Daytona Low Profile Long Reach 100%
chris7197381.50
yousefnjr6218.00
      04-24-2024, 07:12 PM   #15
ipilcher
ipilcher's Avatar
498
Drives: 2024 M3 Compensation
Is there any way to safely remove the wheels on these things without a floor jack? I absolutely do not have the space for one, but not being able to really clean my wheels and calipers is driving me crazy.
      04-24-2024, 07:16 PM   #16
TheMidnightNarwhal
What do you mean? How are you going to raise the car and remove the wheels without a jack/lift?
      04-25-2024, 05:01 AM   #17
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
Scissor jack..... not my first choice but it will do the job.
https://bimmerzone.com/products/afte...-and-tire-iron
      04-25-2024, 09:26 AM   #18
ipilcher
ipilcher's Avatar
498
The question was whether there is a safe way to do it without a floor jack.
      04-25-2024, 09:28 AM   #19
ipilcher
ipilcher's Avatar
498
But once you lift a corner of the car up with the scissor jack, how are you supposed to get it onto a jack stand?
      04-25-2024, 09:47 AM   #20
TheMidnightNarwhal
Ahhh mb lol. I didn't realise you meant like scissor vs wheeled jacks.
But yeah if you use a scissor jack you can't really place a stand at the jack point. Instead you can find a spot on the subframe or suspension
      04-25-2024, 04:32 PM   #21
No one
Drives: F21 118i
When they use the professional car lifts they don't seem to target the plastic jack receivers with the lift's paws. I reckon/recall they place the paws next to the points, farther from the wheels.
Dackelone seems to know how to do it: https://www.1addicts.com/forums/showthread.php?t=835379.
      04-25-2024, 06:37 PM   #22
MADBMWX5MC
MADBMWX5MC's Avatar
1017
Drives: 2023 BMW X5MC
That Daytona looks slick, I have the Pittsburg one I use on my 2006 Mustang...
2023 BMW X5MC Tanzanite Blue II Metallic
2021 Jeep Grand Cherokee SRT Black
2006 Ford Mustang GT Convertible (show car)
f30post
