F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > 2013 F31 lower grille bird strike
ARMA SPEED
      04-10-2024, 03:09 AM   #1
Bazza
Bazza's Avatar
England
Drives: 330D xDrive M Sport 2016
My wife's 2013 F31 touring M Sport took a bird strike the other day when a young pheasant decided it wanted to go to work with her. Hopefully you can see from the attached pictures that the grille doesn't appear damaged but has popped off from the clips. I have no idea what's involved in putting this back in place. Any help and advice would be much appreciated.
Thanks.
      04-10-2024, 08:15 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
As you surmised it just clips in place. You should be able to pull it back into position.
      04-12-2024, 07:39 AM   #3
Bazza
Bazza's Avatar
England
Thanks. Now I just have to work out how to put them back in place.
      04-12-2024, 08:18 AM   #4
Billfitz
Billfitz's Avatar
https://www.amazon.com/National-Hard...EQAvD_BwE&th=1
      04-12-2024, 08:21 AM   #5
Bazza
Bazza's Avatar
England
I think I have some similar in the garage. Cheers.
      04-12-2024, 09:29 AM   #6
erickonphoenix
erickonphoenix's Avatar
1739
Drives: 2014 Gray 328xi Touring
If you want access to the back of that you can get there through the wheel well cover. You may even just go through the access panel even. Depends on how small and flexible your arms are.
      04-12-2024, 09:54 AM   #7
Billfitz
Billfitz's Avatar
True, but that involves jacking the car up and removing the wheel. I'd do that only if it was the only alternative.
      04-20-2024, 05:41 AM   #8
Bazza
Bazza's Avatar
England
Update.
There was a lot more damage inside than could be seen from an external view. The fog light mounts had broken and I had to replace it with a new one. The grille went back in no problem.
Tags
bird strike, f31 3 series touring m sport, lower grille
f30post
