F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > metal intake manifold
proTUNING Freaks
      07-13-2022, 06:50 PM   #1
eyespider
Drives: bmw 435d xdrive convertible,
Does any one know if this will fit 435d? I've melted two since ive had this car. It shows up in the results for the n57 inlet part number? however it's not on real oem.
      07-14-2022, 02:35 AM   #2
Watsey
6450
Drives: F31 330D sDrive M Sport
Why is your inlet air temperature is so high that it's melting plastic ?
In your shoes I'd be fixing that problem rather fitting a metal IM.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
Enabled1420.50
      07-14-2022, 06:17 AM   #3
Enabled
Drives: 328xd Wagon, M2 Competition
Exactly. You are hurting your engine, there's no performance associated with plastic-melting IATs, and you're damaging sensors.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      07-14-2022, 10:29 AM   #4
eyespider
Thanks for the reply's I've had ports walnut blasted now, I'm just looking for a cheap inlet manifold to put on whilst i clean out the old one. This is when I came across the metal one.
Also I notice there's a new recall for the egr cooler. so hopefully the melt problems will never happen again.
      07-15-2022, 03:39 AM   #5
Watsey
6450
Seems like a lot of hassle to buy / remove / fit / clean / remove / fit.
Can you not just remove / clean / dry / refit over one weekend ?
Or get the job done by an Indy who has an ultrasonic bath - I had my IM cleaned that way and it came out as-new.
Fingers crossed the EGR cooler recall fixes your problems. BMW provides a two year warranty on its repairs so you'll have that peace of mind whatever happens.
      07-15-2022, 09:20 AM   #6
eyespider
I had the egr cooler replaced on my 435d in 2020.
you can fold down the heat shielding thing and see the part number of the cooler that bmw fitted. It was 847699301
I initially thought they'd redesigned the part and given it a new number however on further investigation it's 420d part. to be fair it's worked ok until recently when I've had to start topping up the coolant again.
      07-15-2022, 02:08 PM   #7
Lloydy1980
Lloydy1980's Avatar
36
Drives: BMW F31
Just get the EGR functionality removed from the ECU and install the blanking plugs for good measure. Egrs are the root of all evil and the engine will last far longer without it!
      07-16-2022, 10:40 AM   #8
eyespider
Is this possible on the F30 will it need to be coded out?
      07-17-2022, 07:18 AM   #9
Watsey
6450
Yes, the operation of the EGR can be coded-out but it's typically a job for a tuner rather than DIY (i.e. Bimmercode or similar) as it involves reprogramming the ECU.
Coding usually involves programming the EGR to be 100% closed 100% of the time. A thin metal blanking plate can also be introduced between the exhaust manifold and the entry to the EGR cooler to make absolutely sure the EGR circuit is closed.
      08-15-2023, 10:20 PM   #10
Stephen long
Drives: BMW 335d
What part !
This is from the m50d
      05-08-2024, 10:55 PM   #11
M3HNGRY
Drives: '18 AW X5 35d Msport
This is incorrect....
      05-09-2024, 09:04 AM   #12
TurboWeasel
Drives: BMW 330D
You reopened a 9 month old thread just to say that?
It doesn't matter anyway. OP was melting runner flaps from a defective EGR which is nothing to do with metal vs plastic intakes.
f30post
