04-26-2024, 08:18 PM | #1 | |
Rep 14
N55 Valvetronic Issues, what a surprise
So my dumbass overpaid for a 2013 335i that clicked every time I opened the door, I just overlooked it bc German cars and weird sounds are like cake and ice cream
The ‘woodpecker’ noise is coming from the valvetronic motor, and I was just planning on replacing that to fix the problem. No rough idle, just some power loss, and no check engine lights even tho I am getting one valvetronic malfunction code The eccentric shaft gear has some wear, but nothing out of the ordinary for a higher mileage car, but the worm gear is clearly damaged. Currently am not driving it because I don’t want to damage the shaft anymore in hopes of being able to reuse it. Should I reuse it? I have all the necessities to install and relearn the motor, but I haven’t bought anything because I’m not sure if just the motor would fix it. Quote:
04-27-2024, 09:24 PM | #2 | |
Rep 10,393
Pics?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
04-27-2024, 09:40 PM | #3 | |
Rep 14
I think the squirter got plugged which caused the initial failure as the shaft and motor both move freely. I bought a new actuator, oil squirter, recess gaskets, decoupling agents and seals for the injectors I have to remove to do the job. Gonna start with that and if it fails again, it’s under warranty. 100$ deductible is a hell of a lot better than an 1800$ eccentric shaft rebuild kit yk? |
04-28-2024, 12:29 PM | #4 | |
Rep 10,393
GL with the repair.
