F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
Extreme Powerhouse
      01-14-2018, 07:35 AM   #1
Jagaer
Drives: 2011 E91 328xi 6MT
This is (hopefully) a more user-friendly CIC/NBT FSC Key Generator for Windows, Linux and OSX based off of the work of the original FSC Key Generator and Intel123's certificate Patcher.
Input Files
  • The Key Generator will auto-detect and accept either Base64 (Text) or binary FSC file inputs, as well as the file type (1B or NBT). (You can over-ride the detection setting, using the "CIC/NBT" radio buttons).
Support Files
  • The Key Generator will download and use the most recent copy of the BMW "Lookup.xml" file for key generation parameters. In Linux and Windows, this file is stored in the same directory as the Key Generator. For OSX, it is stored in ~/Downloads/
  • The RSAKeys.txt file keeps a copy all submitted RSA keys. The Generator will download and use the most recent copy of the file. In Linux and Windows, this file is stored in the same directory as the Key Generator. For OSX, it is stored in ~/Downloads/
Unsupported Feature
  • It appears that the key stored in the "FSC" file pulled from the car is not necessarily unique to the car, but may be shared across multiple cars built within a short time window.
As an example:
Code:
FSC Date	VIN Build Date			Days Difference
200910211749	Thursday, October 22, 2009	-1
201001271515	Thursday, January 28, 2010	-1
201004011026	Monday, April 04, 2011		-3
201006071536	Tuesday, June 08, 2010		-1
201107121301	Wednesday, July 13, 2011	-1
201110310756	Wednesday, November 02, 2011	-3
201201111004	Thursday, January 12, 2012	-1
201203301822	Monday, April 02, 2012		-4
201204181719	Wednesday, April 18, 2012	0
201205242316	Friday, May 25, 2012		-1
201210010521	Tuesday, October 02, 2012	-1
201210010703	Tuesday, October 02, 2012	-1
201210241654	Thursday, October 25, 2012	-1
201211081709	Friday, November 09, 2012	-1
201305140635	Wednesday, May 15, 2013		-1
201308142104	Friday, August 16, 2013		-2
201403071931	Monday, March 10, 2014		-3
201404091427	Thursday, April 10, 2014	-1
201404300545	Friday, May 02, 2014		-3
201406241001	Tuesday, June 24, 2014		0
201406241307	Tuesday, June 24, 2014		0
201409161938	Wednesday, September 17, 2014	-1
If you would like to help out, and have pulled your FSC file, please send me a copy. I will not include or publish any car-specific information, but will add the FSC file date and RSA key to the RSAKeys.txt file. Hopefully if enough are gathered, some people will be able to create an FSC for their car, without having to pull any files.
  • Windows: https://ufile.io/zkhli175
    Windows users must extract the file to a writeable directory (Desktop, Downloads, etc...), not run it from the zipped file. The generator needs to download support files (Lookup.xml and RSAKeys.txt) in order for it to run correctly.
  • Linux: https://ufile.io/wf40lkit
    Linux users must extract the file to a writeable directory (~/) and will need both QT5 and OpenSSL installed.
  • Linux Console: https://ufile.io/tb2tia4k
    Linux users must extract the file to a writeable directory (~/) and will need both QT5 and OpenSSL installed. Network not required.
    Code:
    Usage:  ./BMW_CIC_FSC_Generator_Console FILE.fsc TYPE [TYPE] YEAR [YEAR]
                    Example ./BMW_CIC_FSC_Generator_Console FILE.fsc 0x28 0x0A
            FILE.fsc - 319 byte hex OR BASE64 encoded version of hex
            TYPE     - 1 or 2 bytes representing the map type
                       If TYPE is two bytes, YEAR must be two bytes
            YEAR     - 1 or 2 bytes representing the map year
                       If YEAR is two bytes, TYPE must be two bytes
Code:
Version History
v1.91
  Feature: Option to attempt to repair corrupt 1B file
  Bugfix:  Download/Rename Lookup.xml
  Misc:    Add "Select Option" to dropdowns, since I'm tired of answering "Click 'Premium'. Select 'Premium', then the next dropdown will become enabled"
v1.9 - Add support for F0 Files.  NBT EVO Headunits which use NEXT style maps.
v1.02 - Allow Numerical First Digit for VIN.  Bug Identification & Explanation provided by txomin in post 71
v1.01 - Unhide "Lifetime" Checkbox
v1.0  - Initial Release
      01-15-2018, 08:55 AM   #2
djekl
djekl's Avatar
Drives: F30 2014 Estoril Blue M Sport
Here is the short vin from 3x NBT units, and the codes
F149333 - WIGHHJ63ZHXEAAFJAD7Q
K566308 - F4LCSEQKXQ2BOAFJAD7Q
KE95871 - YGF6C2VRX5KI6AFJAD7Q
ez_2get13.00
      01-17-2018, 05:23 PM   #3
a803sgo
Drives: BMW 320D M-SPORT (F30)
Works lovely, thanks.
      04-06-2018, 06:54 PM   #4
SimonChu
Drives: 330d
Hi,
could you maybe reupload it?
      04-06-2018, 06:59 PM   #5
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
Originally Posted by SimonChu View Post
Hi,
Would love a copy also
      04-07-2018, 05:33 PM   #6
Jagaer
Links updated
      05-19-2018, 07:36 AM   #7
Jagaer
Linux Console version added
      06-11-2018, 01:17 AM   #8
Master_
Master_'s Avatar
Drives: F11 520d
Many thanks, very helpful software! Will send you few fsc files.
      06-15-2018, 09:57 PM   #9
zvizdic
Drives: BMW328xi,328xi, F25X3
Hi Jagaer
Is this able to run on 64 bit system or just 32 bit like the other one.
      06-18-2018, 02:20 AM   #10
kamranlpr
Drives: f30
apple CarPlay
hi
can i use this app to generate FSC code to active apple CarPlay?
      06-23-2018, 05:52 AM   #11
BMW735
Perfect tool, thanks.
      06-23-2018, 01:06 PM   #12
zvizdic
It worked for my car , little complicated to get 1B file for my CIC .
      06-23-2018, 01:52 PM   #13
deneyer
Belgium
35
Genarated the code by date maybe that doesn't work
Then searched net(found sollution), used esys to read and create fsc file, used file to genarate code and now its installing
      06-23-2018, 08:44 PM   #14
zvizdic
To put in short description yes that is the way.
production date 01,02,2011 North America Premium code
6WBJ4MHHYPORYABNAAWQ
      07-08-2018, 02:55 PM   #15
jjan
Drives: 535D 2011
Hi Jagaer
Hello Jagaer,
For me the same question. FSC generation by file generates a fsc code, but bij Date I can't select any date, its grayed out.
I'm using WIN10 64 bit
Thanks for your reply
Jan
      07-10-2018, 01:03 PM   #16
alanek151
Drives: bmw f11 535d
Hello Jagaer,
sory for my English. I heve problem I canīt FSC code generates my Map:
Road Map europe Next 2018-1
and my vin D088939
could you help me pleas?
      07-13-2018, 04:26 PM   #17
bo0tn1c
Drives: BMW F30 M Sport
Originally Posted by kamranlpr View Post
hi
nope this tool is only to generate an FSC code for maps
      08-18-2018, 04:18 PM   #18
jacobniell
jacobniell's Avatar
Denmark
15
Drives: BMW 335i
2007 335i  [0.00]
Input Files
Support Files
Unsupported Feature
As an example:
Code:
Links expire 21 August 18
  • Windows: https://ufile.io/ps23e
  • Linux: https://ufile.io/jy5bt
  • Linux Console: https://ufile.io/80gla
    Code:
Code:
Version History
How do you pull the 1b and DE codes from the car? As I read this this program can translate the 1b code to a new FSC code but how do you get the 1b/ DE code from start?
      08-18-2018, 04:20 PM   #19
jacobniell
jacobniell's Avatar
Denmark
15
Drives: BMW 335i
2007 335i  [0.00]
Originally Posted by jjan View Post
Hello Jagaer,
Jan
Did you solve your problem?
      08-18-2018, 08:36 PM   #20
Jagaer
Hello Jagaer,
Jan
The generator forces you to select each option, which is why it is greyed out.
Enter your VIN. If the VIN isn't valid, it will not let you select a date.
Select a Date, and the Map Type field will become active.
You need to select a map type. Even if "Premium" is displayed, it will not let you select a region until you click on "Premium"
You need to select a region. Even if you want "Arabian Gulf", it will not let you select a Map Year until you click on "Arabian Gulf". etc...
I hope this is a bit more clear.
      08-20-2018, 05:24 PM   #21
reprobcn
Drives: x6 40d xdrive year 2012
hi
is problem for x6 year 2012
FSC code please
vin: L853473
ROAD MAP EUROPE WEST PREMIUM 2018-2 USB
Testing keygen invalid code
      08-22-2018, 03:45 PM   #22
Shophopper
Drives: BMW M550d
Thanks Jaeger! If I may suggest a future improvement:
A lot of users seem to have problems adding a new release date to the lookup.xml file. For example: 2020-1 is not in the lookup file yet and nobody knows how long BMW will stick to the current byte pattern to identify releases. You might want to add edit boxes to enter the map type and release date as byte values, as an alternative to the dropdown boxes with fixed lookup values.
f30post
