F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > I can't get rid of this leak, my goodness
Studio RSR
      04-30-2024, 07:47 AM   #23
NxTH
AH3 Owner
NxTH's Avatar
206
Drives: BMW 335i ActiveHybrid 3
Originally Posted by Billfitz View Post
I replaced my cap with the BMS years ago, not because of leaking but because aluminum sheds heat, plastic doesn't. With luck that will make the housing gasket last longer. Beware that the plastic cage that the filter sits on is transferred from the original cap to the billet cap, and it has a tendency to come off the cap when you're changing the filter, which can leave you wondering how to put it back together again. Worse, if you're not careful it can fall out of the cap and the parts will scatter.
So...did mine break? It was REALLY hard to remove. I don't know if there's a technique for it, but in the videos they just twisted it out in an angle so that's what I did. The bottom and the spring came out and they don't push back in or maybe I don't know how to put them back? Do I need a new cage? No matter how much I press, the bottom flies out. It goes in without the spring, but with the spring it flies out.
      04-30-2024, 04:56 PM   #24
Eschmacher
Car Hypochondriac
Eschmacher's Avatar
Drives: 2014 335i M-Sport Estoril Blue
2014 BMW 335i  [0.00]
Sounds like yours did what mine did. https://f30.bimmerpost.com/forums/sh....php?t=1548912
I just bought another OE type oil filter cap and stole the cage from it to put in the billet one.
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff
Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser
Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327
      04-30-2024, 04:59 PM   #25
NxTH
AH3 Owner
NxTH's Avatar
206
I wonder if this is the cause of my random vanos codes despite having maintenance done on the vanos. Come to think of it, how would I have damaged the cage myself when taking it out? The bottom doesn't touch any surface even if I ripped the cage out by force. This would explain why the cage was super hard to remove and it took quite a bit of manhandling, the spring must have already been under tension and the cage literally exploded when I took it out. So it probably wasn't working right to begin with. I ordered a new one.
      05-02-2024, 08:45 AM   #26
NxTH
AH3 Owner
NxTH's Avatar
206
New cage arrived, and the new cap is installed. The cage did take a mallet hit, wouldn't go in otherwise. Went for a few drives, did some pulls and so far it seems to hold. I will report back if and when it reoccurs, or post anyway if this solves it. Something tells me the cage was already broken on the old one..
      05-02-2024, 11:57 AM   #27
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Should have gotten it in red.
f30post
