F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [DIY] KAFAS2 for SLI or 5AS retrofit for F3x
ARMA SPEED
      04-10-2023, 04:34 AM   #111
daMANiack
daMANiack's Avatar
Drives: BMW F26 X4 35d
Hi,
So I need to remove 8TD and add 8TH, then VO code and code Kafas2, HU_EntryNav and Kombi ECU's.
Originally Posted by TheNine90 View Post
Flashing only upgrades the software files, the FSC remain untouched.
Adding 8TH is necessary.
2016 BMW F26 X4 35d, H&R spring lowered 30mm, QUAD exhausts
      04-10-2023, 07:54 AM   #112
TheNine90
Drives: bmw
yes
      04-11-2023, 01:57 AM   #113
daMANiack
daMANiack's Avatar
yes
Hi,
Struck a problem changing 8TD to 8TH when I try to FA_Calculate.
Error:
com.bmw.esys.domain.psdz.PsdzException: No FP could be generated from FA "". [C002]
at com.bmw.esys.domain.psdz.Psdz.generateFP(Psdz.java :649)
at com.bmw.esys.domain.fa.FpLogic.generateFp(FpLogic. java:84)
at com.bmw.esys.gui.fa.FpController.generateFp(FpCont roller.java:114)
at com.bmw.esys.gui.fa.FpController.execute(FpControl ler.java:146)
at com.bmw.esys.gui.AbstractController$ExtensionSuppo rt.executeExtensions(AbstractController.java:117)
at com.bmw.esys.gui.AbstractController$ExtensionSuppo rt.executeExtensions(AbstractController.java:98)
at com.bmw.esys.gui.AbstractController.executeExtensi ons(AbstractController.java:201)
at com.bmw.esys.gui.fa.FalController.activateFa(FalCo ntroller.java:144)
at com.bmw.esys.gui.fa.FalView$ActivateFaAction.doAct ionPerformed(FalView.java:111)
at com.bmw.esys.gui.AbstractView$AbstractGuiProgressA ction$1.init(AbstractView.java:425)
at com.bmw.esys.gui.component.DialogProgress$2.constr uct(DialogProgress.java:152)
at com.bmw.esys.gui.component.SwingWorker$2.run(Swing Worker.java:145)
at java.lang.Thread.run(Thread.java:744)
Caused by: Not all elements of the FA were found in the FA2FP: SALAPA 8TH
Timestamp: Tue Apr 11 13:42:54 CST 2023
ErrorCategory: SYSTEM_ERROR ID: 72
Class: com.bmw.psdz.api.data.FP
ExecutionContext={category=UNDEFINED, ecuid=(UNKNOWN,?)}
at com.bmw.psdz.api.data.FP.fillByFA(FP.java:413)
at com.bmw.psdz.logic.facade.LogicImpl.generateFP(Log icImpl.java:566)
at com.bmw.psdz.facade.LogicBF.generateFP_aroundBody2 0(LogicBF.java:111)
at com.bmw.psdz.facade.LogicBF.generateFP_aroundBody2 1$advice(LogicBF.java:55)
at com.bmw.psdz.facade.LogicBF.generateFP(LogicBF.jav a:1)
at com.bmw.esys.domain.psdz.Psdz.generateFP(Psdz.java :647)
... 12 more
Any suggestions greatly appreciated or is 8TD to 8TH out of the question due to limitations within the 2016 F48 X1 25i with HU_EntryNav?
Cheerz
      04-11-2023, 02:21 AM   #114
maaii11
Drives: Mini F54
Remove 8TD and VO code Kombi, Kafas , HU. X1 didn't have 8TH.
If your country didn't support SLI, maybe you need to FDL code COUNTRY_MODE in Kafas.
      04-18-2023, 06:41 PM   #115
daMANiack
daMANiack's Avatar
Hi,
Thanks, got it working in Australia after removing 8TD and VO code Kafas2, Kombi, HU_NavEntry and BCD_Body.
I know it wasn't necessary to code BCD_Body, I just saw that others did so decided it couldn't hurt.
Cheerz
      10-11-2023, 06:56 AM   #116
Trickd122
Drives: F10 528 E39 ///M5
I recently acquired the KAFAS2 module and camera. I'd like to do this retrofit to my F10. Can anyone provide details on the wiring harness needed from the kafas to the car? I'm thinking of doing this with a factory look. Yes the windsheild is on order.
      10-11-2023, 07:34 AM   #117
Siki78
Siki78's Avatar
145
Drives: F30,G30
https://f10.5post.com/forums/showthr...1315706&page=2
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      04-27-2024, 07:17 AM   #118
simplextibi
Drives: bmw f25
Hi
Can you provide fsc for kafas 2
F25
Driving assist plus retrofit
thanks
f30post
