F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding cable and ESYS, psdzdata
Studio RSR
      02-21-2024, 05:23 AM   #3521
Martin99
Drives: f33
esys
hi.
i want to deactivate adaptive headlight becouse i change my front lamps to non adaptive.
i tried to remove 524 from fa and code fem but when i tryied to code fem there are showing 2 faults:
Abort!
Asynchrone programming failed! [C049]
task extension configuration missing in container - maybe the template is too old [1906]
im using a e-sys 3.25.3 installed 3 years ago
Do i need some newer PZD ? ive got 20.03.540
thanks for help
      02-21-2024, 09:39 AM   #3522
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by MatrixRev View Post
Hi Shawn,
Can u share a link to psdzdata 4.46.1x.
Thanks
Originally Posted by alg222 View Post
BMW F34 GT
I step (current): F020-23-07-530
What version of psdz/esys should I be using?
I have psdz 4.45.10 and it only shows me CAF options up to F020-21-XXXX
Thanks!!
Originally Posted by Martin99 View Post
hi.
Abort!
thanks for help
PM's sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-20-2024, 02:06 PM   #3523
costy.colceag
Drives: BMW 5 series
Hello
Do you guys know an e-Sys psdzdata full torrent?
i got something from Mega but is not working it says CAFD file missing
thanks
      03-20-2024, 05:11 PM   #3524
shawnsheridan
Originally Posted by costy.colceag View Post
Hello
thanks
PM sent.
      05-09-2024, 07:51 AM   #3525
Modeup
Drives: BMW F30
Hi Shawn ! Been messing with my new f30 bmw , if I could get the torrent for newest safe esys and the compatible psdzdata to start learning coding for my bmw. Thanks , great topic + great Shawn here! Cheers from Bulgaria !
      05-09-2024, 11:00 AM   #3526
shawnsheridan
PM sent.
      05-14-2024, 03:30 PM   #3527
KaraM320
Drives: Bmw 320D
Hi ShawnSheridan,
I still see you going on strong, thanx for all the effort man.
Some mechanic has pulled a number on my ac compressor clutch. About two years ago I had to renew my timing chain and what I think they did was, they replaced my magnetic ac compressor with a regular one that is a bit shorter, so it messed up my belt that runs over it a few times. Local garage told me that he had to renew the belt, because it was sliced. Normally it is not very visible, but when I made a long trip I checked the engine bay regularly to see if everything was okay. And there it was, the belt went over the pulley. On my holiday location I got it set back again on the pulley, but it went over it again. But my ac worked just fine and the belt was not going to brake any time soon, so when I got back home I had it replaced with an original. But now my ac doesn't work because the clutch is not engaging, so only hot air. I think the bad mechanic has changed the compressor and coded the magnetic clutch off.
I read somewhere that it can be coded to get the ac clutch engaged in Esys. Now I need the program again, since I have a new laptop and the old Esys is not working anymore, I need a new working Esys. Can you help me out.
      05-14-2024, 05:32 PM   #3528
shawnsheridan
Originally Posted by KaraM320 View Post
Hi ShawnSheridan,
PM sent.
f30post
