F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Ultimate DIY guide
proTUNING Freaks
      05-05-2014, 02:14 PM   #45
RJCrew
RJCrew's Avatar
Drives: 2016 ///M4 ZCP SO/SO
Just finished installing ER DP to my 2012 335i F30..super easy. I used this thread for directions..
http://www.2addicts.com/forums/showt...php?p=15763253
      05-16-2014, 07:47 AM   #46
2blu
2blu's Avatar
Drives: 540i XDrive ///M Sport
Added !
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
      07-10-2014, 12:01 PM   #47
Korean_Bob
Drives: 2014 435ix M-sport
As a first-time BMW owner, this sticky is excellent. After I spent a whole day combing through the DIY forum looking for the ones I wanted. At least I can take comfort in the fact that ones listed here are the ones I liked the most as well.
Cheers,
A
      09-16-2014, 08:41 PM   #48
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
can you add the rear PDC DIY to this thread? will compliment the Front PDC nicely...)...
http://f30.bimmerpost.com/forums/sho...d.php?t=976142
      09-19-2014, 07:37 AM   #49
2blu
2blu's Avatar
Added to the list !
      09-19-2014, 10:17 AM   #50
Frogman
Drives: 2012 F30 328i
Originally Posted by 2blu View Post
Added to the list !
Might as well add this one too...
http://f30.bimmerpost.com/forums/sho...d.php?t=974007
      09-20-2014, 07:38 AM   #51
2blu
2blu's Avatar
Added, thanks for the contribution !
      10-24-2014, 05:01 AM   #52
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
anyone know how or where i can see a DIY for removal of my stock Msport rear diffuser, to replace with a Quad diffuser???
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      10-24-2014, 08:46 AM   #53
2blu
2blu's Avatar
There aren't instructions in the PDF for the aero package, but it's fairly simple, I did it myself. From what I remember, there are about 7-10 screws and pins that hold it in place, just look under there and you'll see them. Pop the pins out and unscrew the screws holding it in, then gently pull on it and it'll unclip from the bumper.
You then clip the new diffuser in place and pop the pins and screws back in.
However, with my non-OEM diffuser, it wasn't fully holding in place with just the clips. During your installation of the quad diffuser, don't be worried if that happens. If it's not fully holding up or lining up perfectly with the clips alone, start by putting the screws in, and then put the pins in and it should then fit like a glove.
      10-24-2014, 03:12 PM   #54
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
ok , i will give it a try, i am going on Tuesday to my exhaust guy.
Soon:
      10-31-2014, 02:30 PM   #55
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
DYI Front Kidney Grill / Grille removal and replacement
DYI is somewhat old. Will this still apply to F32 435i as well?
      11-02-2014, 09:46 AM   #56
2blu
2blu's Avatar
I believe so !
      11-03-2014, 02:32 PM   #57
ronanz
ronanz's Avatar
I believe so !
Yup! Confirmed...
      03-18-2015, 02:21 PM   #58
Moisted
Moisted's Avatar
Drives: 2015 335i F36 GranCoupe EBII
Is there a DIY for the side grilles? ... Couldn't find any. I know it's probably easy, but a DIY would be nice for the young and cautious.
2015 435i GranCoupe F36 Xdrive PPK
Estoril Blue II Ivory/black
      03-19-2015, 10:07 AM   #59
2blu
2blu's Avatar
Haven't come across any ! Did a quick search and came out blank.
      06-12-2015, 11:21 PM   #60
TheFeelOfAFullTank
Drives: F30 328i Sportline
Awesome thread! Here's a DIY for replacing halogen bulbs. For some reason your link for Xenon bulb change is for an e90 which doesn't have the access point.
http://f30.bimmerpost.com/forums/sho...d.php?t=865909
      08-26-2015, 01:32 AM   #61
Dante
Enthusiast
Dante's Avatar
Germany
468
Drives: F87 M2 / F31 330d
Hi,
posted up a DIY: Illuminated LCI AC/radio trim retrofit
Maybe you want to add it to the list for interior modifications?
Thanks
Christian
      08-26-2015, 11:35 PM   #62
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
Here's a DIY i did for the trunk liner removal:
http://f30.bimmerpost.com/forums/sho....php?t=1086883
A bunch of people have referred to it for replacement of the OEM amp, which sits on the left side of the trunk area just under the cargo/cubby hole.
      05-23-2016, 06:40 PM   #63
beamer1
Drives: 2013 BMW 328i
May not be the right place for this but here goes. I need the wiring diagram a 2013 328i. My passenger door lock does not operate at all from the central control or the fob. I know it is probably the actuator but I would like to confirm prior to the actual tear down and replacement. Does anyone have the wiring diagrams. All I find on the web is for the older generations. Thanks in advance for any help.
      06-17-2016, 07:44 PM   #64
thesull
Drives: e30>e36>e46>e90>f30
Anyone know where to find a guide for installing the V2 Carbon Lip on an F30?
Like this one below?
      09-13-2016, 10:13 PM   #65
overkill1125
overkill1125's Avatar
Drives: 2019 440xi Gran Coupe
I know there's a diy for for m sport lip install on the f30 but the lip on the f32 is different and would like to know if it's the same? I believe the install screws/rivets used is similar but not identical but would like to get some confirmation from those who did the f32 install.
Thanks for the help!
      09-19-2016, 11:45 AM   #66
Vinboyblue
Drives: BMW 335
Is there a Brake pads DIY?
f30post
