F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [SOLVED] Speed limit failure after retrofitted M steering wheel
Extreme Powerhouse
      07-03-2022, 05:00 AM   #1
ReMiii40
Newbie with some skills
ReMiii40's Avatar
22
Drives: BMW F30 318D Luxury
Hello everyone,
My car comes with a multifunction steering wheel with set and reset button
  • S249A : Multi-function For Steering Wheel
  • S544A : Cruise Control With Braking Function
  • S255A : Sports leather steering wheel
I’ve retrofitted a long ago LIM function (with F30 cheat sheet)
  • ICM 3000 :
    SLD_FUNKTION : aktiv
    C_Umschaltung_ACC_DCC : already zugelassen
    LDM_SET_Taste : Doesn't exist
  • KOMBI 3003
    SLD_ENABLE : aktiv
Work flawless during months;
Today I’ve retrofitted the M steering wheel with LIM button :
Media buttons works but LIM function doesn’t : LIM SPEED LIMIT FAILURE on instrument panel/CIC….
Error memory : MFL wrong variant
I've coded :
  • FEM 3140 :
    LIN_VARIANTE_MFL : DCC_Sports to DCC_Sports_SLD
No more memory errors, but the LIM function does not work...
Could you help me with this problem ?
Edit :
  • Delete S255A + add S710A in VO (FEM, ICM, KOMBI) + LIM : malfunction and error memory MFL wrong variant
  • MFL DCC_Sports + LIM : malfunction
  • MFL DCC_Sports_SLD + LIM : malfunction
  • MFL M-Sport + LIM : malfunction
Retrofit : S676A, S3AGA, S481A, S488A, S459A, S5ACA, S5DCA, S6NKA, S8THA (emulator), S710A
      07-06-2022, 04:10 AM   #2
ReMiii40
ReMiii40's Avatar
22
Nobody ?
Temporarily I disabled the LIM function, so I use the LIM button like the SET button. I can live without the LIM function but I need to find a SET button for the M Sport steering wheel, do you know where I could find this button?
      07-06-2022, 06:04 AM   #3
DJSF3014
Drives: 2020 m340i
Originally Posted by ReMiii40 View Post
Nobody ?
Doubt you will find the set button by itself you'd have to order the whole set of buttons. As for the other no idea I don't code.
      07-08-2022, 01:37 PM   #4
ReMiii40
ReMiii40's Avatar
22
Lightbulb solution below
Good news guys! I found how to activate the LIM function. An additional FDL must be coded. It's soooo weird because with the Sport steering wheel I just needed regular FDL codes (found on Super Cheat Sheet), I've read tutorials for X5, X3, Series 1, 3 and 4, no one talks about this extra FDL code.
I use ESYS for VO code S710A + S249A + S544A, so my car come without any FDL modifications;
  • ICM 3000 :
    SLD_FUNKTION : nicht aktiv
  • KOMBI 3003
    SLD_ENABLE : already aktiv
I just changed that
  • ICM 3000 :
  • KOMBI 3000 (not 3003!) :
    SPEED_LIMIT : aktiv
  • FEM 3140 :
And it's work
      07-17-2022, 11:20 AM   #5
Durbelik
Ukraine
Drives: BMW F30 328iX, BMW F10 53iX
Thx for guide
      08-08-2023, 11:44 AM   #6
Teodor.St
Teodor.St's Avatar
Drives: BMW F30 335i
Great info, thank you very much. I managed to remove all errors for wrong steering after retrofitting the M Sport steering wheel.
I must add that I also had to change
LIN_VARIANTE_LRE
lre_tlz_lhz -> lre_lhz
I also had LRE invalid version error.
      08-15-2023, 08:48 AM   #7
Grateful_Newt
Drives: 2015 BMW 320i
In which module did you find this value to change? When I run codes, I also have one for steering wheel: incorrect variant.
      08-15-2023, 09:30 AM   #8
TheNine90
Drives: bmw
Its in the FEM
      08-16-2023, 03:22 AM   #9
ReMiii40
ReMiii40's Avatar
22
Originally Posted by grateful_newt View Post
in which module did you find this value to change? When i run codes, i also have one for steering wheel: Incorrect variant.
In FEM > 3140 > LIN_VARIANTE_LRE
Originally Posted by fbmwwins View Post
LIN_VARIANTE_LRE = set with the lre_tlc_lhz parameter if car as lane departure warning (vibration) and heated steering wheel
      05-08-2024, 10:45 AM   #10
rodrig0111
Drives: BMW 116ED
Nobody ?
Hi, i have retrofit a multifunction steering wheel and program it to the buttons work but my lim button causes a error on the traction control so i'm wondering how you have disabled the lim
f30post
