F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > HK stereo cutting out after sub and amp install please help
proTUNING Freaks
      05-02-2024, 05:28 AM   #1
patsf1
Drives: 320d se
HK speakers cutting out after about 30 seconds of listening then popping. Sounds like a loss of signal. Please help, just installed sub and amp with technic add a sub harness. Thanks guys
      05-02-2024, 07:37 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
That may indicate a short circuit in the speaker wiring, causing the amp to go into protect mode.
      05-02-2024, 07:56 AM   #3
patsf1
Drives: 320d se
Yes I was thinking that but would that be the pnp harness shorting? Or something in the HK amp Will have to strip out and investigate
      05-02-2024, 09:17 AM   #4
Arthurrs
Drives: 2017 430i xdrive Gran Coupe
Check to make sure the additional amplifier is at the same ground reference as the factory amp.
2017 430ix Gran Coupe
patsf16.50
      05-02-2024, 10:54 AM   #5
patsf1
Drives: 320d se
Where might that be?
      05-02-2024, 11:31 AM   #6
patsf1
Drives: 320d se
I just used the screw with the brown wires coming out of it.
      05-02-2024, 04:06 PM   #7
patsf1
Drives: 320d se
Got it sorted guys, the power wire for the wavtech was loose. All good now thankfully. Beats are nice again.
      05-02-2024, 05:23 PM   #8
Arthurrs
Awesome glad you sorted it out before I had a chance to respond!!
So what did you end up doing for upgrades? I'm getting ready to go down that rabbit hole myself for my F36!! It will be a summer of fun!
      05-02-2024, 11:54 PM   #9
patsf1
Drives: 320d se
Cool, I built this system from old components I had lying around just used the pnp add a sub harness and hooked everything up. Sounds nice!!
      05-03-2024, 09:33 PM   #10
NealfromNZ
NealfromNZ's Avatar
New Zealand
554
Drives: 2016 F80 M3
One of these perhaps ?
https://integralaudio.com/phantom-su...coupe-f36.html
patsf16.50
      05-03-2024, 10:14 PM   #11
Arthurrs
Originally Posted by NealfromNZ View Post
Absolutely! It's on the list along with a Match UP 1 FX!! Paid for by the recent sale of my old F30 audio upgrade equipment I sold to a lucky individual here.
The m0bridge K2 8.1.1 might come later in the summer, after a full color correction of my car, PPF and ceramic coat, I have a few chips to fix with a difficult paint finish to touch up (mineral white). Damn this hobby is expensive!!
I kept my Earthquake under seat woofers and Morel Hybrid 402 for the front doors from my previous F30 install, so it should be interesting to make a comparison with the HK system. This time around I'll take some response measurements with my Smaart rig before and after the upgrades. I have to wonder if a better passive crossover for the HK door speakers might prove beneficial? I haven't opened the door panel yet to see what is there now, but I suspect it's just a capacitor. I'm waiting for it to warm up. Summer tire swap happening tomorrow if the weather is nice!
      05-03-2024, 11:24 PM   #12
NealfromNZ
NealfromNZ's Avatar
New Zealand
554
Drives: 2016 F80 M3
HK and Hifi just use a single capictor on tweeter and nothing for a low pass filter on the door mid.
But Bill has shared a design for a superior crossover build and component for hifi and HK. It would also work with and improve most aftermarket passive crossovers no doubt.
patsf16.50
      05-04-2024, 12:17 AM   #13
NealfromNZ
NealfromNZ's Avatar
New Zealand
554
Drives: 2016 F80 M3
Like how you’ve built the corner sub !
patsf16.50
      05-05-2024, 12:02 AM   #14
patsf1
Drives: 320d se
Thanks, I had an idea of using fiberglass but I got a 1/4 sheet of MDF for £5 and thought why not give it a go and see what happens. So I got the jig saw out, a few swear words and some fettling we got there. It took about a day and a half to sort the box out from scratch. It’s about 15l inside which was the minimum requirement for the sub (focal P 27v2) 300w rms. If anyone is doing a similar setup I would advise using the lowest setting on the crossover, for best results. This things pounds you and it’s clear all the way through the volume range.
f30post
