F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F32 lci icon led adaptive headlight problems
Extreme Powerhouse
      07-13-2023, 08:49 AM   #1
boss25pc
Drives: bmw f32
Hi there
Really hoping somebody will be able to help me on here.
Ive finally just got my car on the road i had to replace the front end panels in front of radiator and a new passenger headlight and the drl module on the
top. all the light parts were direct form bmw.
Since doing this it was fine for a few hours but now on heavy braking or while sitting still i get a whole load of headlight errors and the idrive mostly turns off and back on. I have installed e-sys and ista + and im currently trying to see if i can code in the new pieces.
When i read ecu have no FlE its only there when i read VCM. all the instructions so far ive read from the forums my coding knowledge is about zero.
when i read with ista the idrive tends to go off and sometimes get a load of fault codes that i think are only related to the idrive going off
im really keen to get her back on the road now and get out of the volvo ive been driving.
Thanks for reading
      07-13-2023, 09:25 AM   #2
boss25pc
Drives: bmw f32
scan while light systems going crazy and turning idrive off
      07-13-2023, 09:27 AM   #3
boss25pc
Drives: bmw f32
scan when lights are malfunctioning but idrive on
Name:  new faults 2.png
Name:  new faults.png
      07-13-2023, 09:45 AM   #4
TheNine90
Drives: bmw
It looks like you might be having some wiring or communication issue. Start by coding the modules. Do ista test plan and see what it says
      07-13-2023, 10:06 AM   #5
boss25pc
Drives: bmw f32
thanks for your reply.
Apparently they can only be coded on bmws online portal is this correct?
      07-13-2023, 11:41 AM   #6
TheNine90
Drives: bmw
Doesnt need online. Did you check all the wiring after replacing the front end?
      07-14-2023, 05:22 PM   #7
boss25pc
Drives: bmw f32
I had a mechanic do the install of bumper and light. ive driven the car a bit today and now im getting less codes but it has left me more confused. i think the light code is related to puddle lights that throw a bmw on the floor when opening the door. headlight fault is still intermittent but idrive hasnt been turning off.
      07-14-2023, 10:10 PM   #8
TheNine90
Drives: bmw
Confirm if the lights are correct. Or you can try flashing them using esys.
      07-14-2023, 10:11 PM   #9
TheNine90
Drives: bmw
For interior lights, was anything replaced regarding the lights?
      07-15-2023, 04:04 AM   #10
boss25pc
Drives: bmw f32
Nothings changed accept new complete bumper with fogs and pdc left headlight, left drl moudle. I'm going to try and get headlight fault back today. My full beams one is a lot higher than the other one which I'm not thinking is normal.
      05-06-2024, 09:36 PM   #11
ccqwerty
Drives: 340i
What was the issue
f30post
