F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Drop idling n20 cold start
Studio RSR
      03-29-2024, 03:38 PM   #1
razcat13
Drives: BMW f30
Please can someone help me?
I have a BMW 320, n20 engine, 184 HP, on the first cold start, only when decelerating does the idling decrease, drop, after which it recovers. The rest of the starts work fine.
It has no error codes!
For this problem, several parts were changed without success:
-Thermostat
-spark plugs
- Bosch injectors
-original BMW distribution
- engine temperature sensor
-MAF sensor Bosch
-pvc valve
-oxygen sensor 1 Bosch
-fuel rail pressure sensor
- high pressure pump
-o-rings changed at intake
-rocker cover gaskets changed
All consumables and oil changed at 6000 km
Premium fuel and BMW additive
      03-30-2024, 04:34 PM   #2
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
How did you check the error codes? Did you use ISTA+? After replacing components such as you described, the ECUs need to be reset.
Did you try to reset the throttle and transmission adaptations with ITSA+?
Not sure if these methods work:
https://www.bmwfanatics.co.za/thread...n-reset.89895/
https://f30.bimmerpost.com/forums/sh...13&postcount=2
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
      04-02-2024, 03:34 AM   #3
razcat13
Drives: BMW f30
yes, I reset all the settings with launch and ista +
      04-02-2024, 03:36 AM   #4
razcat13
Drives: BMW f30
the interesting thing is that it only works when the temperatures are low, if they are over 10 degrees celsius there are no more problems
      05-08-2024, 11:42 PM   #5
fe7565
fe7565's Avatar
Did you ever figure this out? I just got to think that maybe your ambient temperature sensor is faulty.
      05-11-2024, 02:51 PM   #6
razcat13
Drives: BMW f30
I checked it, on the tester it is in good parameters
f30post
