04-25-2022, 09:17 AM | #1 |
Rep 18
Not sure if this has been discussed but how does something at 10 Hz accurately display hundredths (0.01). @10Hz and 60mph it updates every 8.8ft. Is hundredth only the internal clock so it would only display say 3.56s and next possible post would be 3.66s?
Looking at purchasing but need some accuracy reassurance first. I would expect the refresh to be much higher to justify accuracy of the posted times in .01 resolution. Thanks |
05-01-2022, 07:30 AM | #2 |
Check out my Youtube @n55david!
1302
Rep 3,550
Drives: 2017 m240i, 2015 X3 x35i
Regardless of the engineering questions. It's been proven to be fairly accurate. I myself have proved it to be within a few hundreds or sometimes thousands of actual time slips.
It's no worse than the margin of error you get with a timing system at a track.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
FlorinQCK-2.50 |
10-26-2022, 06:11 AM | #3 |
Rep 41
Drives: 17 340 M-Perf Ed. Fashion Grey
I can only assume (and hope) the software is analyzing the trend of data points and interpolating to get the last decimal place. Of course that means you have a margin of error, but over the course of 30-100 data points (@10hz), your margin of error should be fairly low.
2017 340i M-Performance Edition (ZE0) - Individual Fashion Grey // Extended Black Merino Leather - xDr 8AT - THP - MPPSK
Previous Cars: 2017 340i xDrive 8AT 2019 Golf R 6MT |
FlorinQCK-2.50 |
01-01-2023, 05:38 PM | #4 |
Rep 1,130
Inertial sensors and timers is how. The AIM Solo 2 has a 10hz GPS and gives the same functionality and racers use AIM. The counterpoint being they also use transponders for the official times. So you probably have a bit of a point.
