F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Android 11 / 12 /13 HU discussion
ARMA SPEED
      07-20-2021, 04:46 AM   #23
cwleth
Denmark
Drives: BMW 440i (F36 LCI 2019)
Originally Posted by RedErik View Post
Well... first post here has all the info you're looking for https://f30.bimmerpost.com/forums/sh....php?t=1699764
Thanks have gone through that but still find it difficult to select a trusted source - AliExpress, HiFiMax, AvinUSA etc.?
Secondly I don't find any information on hardware options for newer cars where AUX has been changed to USB?
      07-20-2021, 06:09 AM   #24
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
2004 E63 645Ci  [0.00]
Forget Avin, you're in Europe - shipping and customs would be way too much. As for the others, well... I'm not convinced that there is a single 100% reliable source. Each seller carries various units, including Snapdragon units. It's up to you to verify either yourself or with the seller that what they are listing is what you are after.
As for the AUX replace with USB on newer models, well... I'm not sure how it works to be honest. Maybe you still need to code in AUX, but I can't tell for sure.
      07-22-2021, 12:30 PM   #25
miss
Drives: bmw x1
what appears on this page is valid for entrynav evo f48 July 2017 without aux socket?
thanks
      07-22-2021, 01:11 PM   #26
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
thanks
None of this info is car specific, it describes Android units in general
      07-28-2021, 06:25 AM   #27
cwleth
Denmark
if I was staying with Android 😂
Sounds like you're ditching the screens?
If you were to start over again with a base 6,5" screen and no option of native carplay, would you then go the Android screen or the MMI box route?
      07-28-2021, 07:01 AM   #28
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
I don't use Apple products, full stop, so I'm not interested in CarPlay option at all. In fact I'm not even interested in Android Auto, in my opinion head unit should do/already does what it suppose to do: navigation and music. Not really interested in any other option - I just care about good experience with these two.
So to answer your question: neither, I would opt for an OEM retrofit that does everything what I want it do (and this is exactly what I'm doing now). I had enough of bad experience with Android for E6x, no thank you. MMI is just simplified Android unit that only does CarPlay so definitely no.
      07-28-2021, 07:55 AM   #29
miss
Drives: bmw x1
Does it say that Avin is in Europe?
I only find the Avinusa page to buy, would you know how to tell me the address of avin europa.
Thanks a lot
      07-28-2021, 08:23 AM   #30
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
Thanks a lot
I said to cwleth to forget about Avin as he is located in Europe - same as you. Avin is US only... I thought this message is pretty clear.
      07-28-2021, 09:03 AM   #31
miss
Drives: bmw x1
I use google translator, that's why these errors.
I'm looking for android unit, but with usb audio output and in europe I can't find it.
you are right that aple or android auto unit is a step back having these screens that already give you everything
      07-28-2021, 09:30 AM   #32
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
Do you have EVO unit that you need USB output?
      07-28-2021, 09:31 AM   #33
miss
Drives: bmw x1
yes, evo
      07-28-2021, 09:44 AM   #34
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
yes, evo
I'm pretty sure that every Android that is working with EVO has to have USB audio.
      07-28-2021, 11:18 AM   #35
SupersixM
SupersixM's Avatar
203
Drives: Bmw X6M
AVINUSA claims they'll have Android 11 SD662 in two weeks so we'll see how that pans out.
      07-28-2021, 04:03 PM   #36
Bodygard
Bodygard's Avatar
Portugal
Drives: BMW 420d
Eventually every new unit will start to come out with Android 11 and new SoC SD662 during this year and the next...
      07-28-2021, 07:28 PM   #37
pierreye
Drives: F10 & G01
I too using Android HU for only music and navigation. But my experience is Android HU is better than native NBT. Reason is I can either run Sygic with free map upgrade for offline map or Waze if I need accurate traffic and hidden police information. My advice for stable system is once you run on stable version (still on 2.3.6) just leave it. Also music does sound better from OEM system when using DAC and also more finetuning EQ to the system. As I have upgraded my speakers and underseat sub, I need better control on lifting signal below 50hz to give the system slightly more bass. This is hard to achieve on OEM system unless you have DSP amp for underseat sub.
      07-28-2021, 08:09 PM   #38
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
Mate my system is stable, which doesn't change the fact that it's shit - again, this is my personal opinion based on the quality of hardware for E6x / E9x and the code behind the KSW system/apps. This is the most messed up thing with thousands of lines of dead weight that is cause a whole bunch of issues. I can write my own apps, I can fix most of the issues I have with the Android software, but I can't fix shitty screen, lack of sensors or CAN communication mess.
If KSW code had face it would look like that
I'm quite happy with the map that is offered for EVO nav and the level of adjustment on EQ for Harman/Kardon system, so that is what I'm choosing to have in my car.
      07-31-2021, 09:03 AM   #39
TheFiX3r
Drives: 2018 X3 M40i
One reseller looks to have something of a walk-through of an actual Android 11 head unit shared on YouTube:
https://youtu.be/lJQGtvvHvv0
      07-31-2021, 11:36 AM   #40
SupersixM
SupersixM's Avatar
203
Drives: Bmw X6M
Yeah, and dudes already in the comment section asking for help lol
      07-31-2021, 11:41 AM   #41
SupersixM
SupersixM's Avatar
203
Drives: Bmw X6M
I like that Bluetooth feature... Never heard anything about that capability until now. I wonder if it will work with streaming while navigating. I wonder what other undiscovered goodies is in there?. Good thing I waited, would of hated to upgrade to Sd625 only for this feature to be exclusive to SD662.
      07-31-2021, 11:42 AM   #42
SupersixM
SupersixM's Avatar
203
Drives: Bmw X6M
Used SD625 headunits in the secondary marketplace in 5 4 3 2 1
      08-03-2021, 06:43 AM   #43
Holiman
Drives: BMW F20 M135i, F30 320i
I am newbie here but having purchased the Android 10 from Avin, They said the same to me as well.
      08-16-2021, 10:34 PM   #44
nobuno
nobuno's Avatar
47
Drives: 535I 335I
I got Android 11. 6/128 However, I am facing a problem that the NBT screen does not appear.
f30post
