F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 340i / 440i (B58) BMW M Performance Power and Sound Kit (MPPSK) Official Release
Extreme Powerhouse
      10-30-2023, 02:55 PM   #1541
MoeTE87
OHIO STATE
MoeTE87's Avatar
721
Drives: 2021 BMW M340i
I put mine on the plastic engine cover when I had my F30.
Present: 2021 BMW M340i Mineral White
Past: 2018 BMW X5 Mineral White, 2018 BMW 340i Alpine White, 2016 BMW F15 X5 xDrive / Glacier Silver, 2011 BMW 335xi / Alpine White, 2008 BMW 135i Sedona Red
      11-07-2023, 11:29 PM   #1542
warpaint340
warpaint340's Avatar
Philippines
127
Drives: Moonstone F80 M3 6MT
2016 BMW M3  [0.00]
having a weird issue with my MPPSK… brought the car home yesterday after putting it all back to stock for a part out and valves worked fine. On my commute today I put it into sport to open the valves and they didn’t open.
I forced the valves open with an MHD+ feature and they opened just fine, so I know the actuators work. I switch it back to the “OEM” setting for the valves in MHD after my drive and it’s stuck open even switching to comfort. I have the option checked in MHD where it opens the valves automatically in sport. I’m assuming it’s an issue with MHD since they updated the app while my car was in the shop. Either way it’s annoying and overcomplicated the valve operation. Even having the “sport = valves open” option checked in the flash settings it doesn’t open
      11-08-2023, 01:15 AM   #1543
Skyhigh
Skyhigh's Avatar
1908
Drives: BMW F36
Remove that option! Others complained from that too! You should not need “always open in sport” option as this is the factory default!
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
      11-12-2023, 11:12 PM   #1544
warpaint340
Philippines
127
2016 BMW M3  [0.00]
Fixed. Previously my valves would open as long as I blipped the throttle in sport, even when the car was off which was nice. Guess I forgot this is how it really was
      11-13-2023, 01:19 AM   #1545
Skyhigh
Skyhigh's Avatar
1908
Drives: BMW F36
So what fixed it?
      03-07-2024, 01:23 PM   #1546
MichaelNRW
B58 Power
MichaelNRW's Avatar
496
Drives: 05/2022 M340i xDrive Touring
I can provide the official German Teilegutachten document for the MPPSK
Can you please send me the document?
      05-16-2024, 12:25 AM   #1547
evilgrim
Drives: 440i
After 1 week of having the mppsk, my valves stay closed even in sport and sport+. Not sure what happened but I noticed the sound is much quieter after one week and when I check both valves stay close in sport mode.
Taking it back to the dealership tomorrow to let them have a look. Has anyone experience this before?
      05-16-2024, 12:56 AM   #1548
Skyhigh
Skyhigh's Avatar
1908
Drives: BMW F36
Yes. With one valve. Discovered it several months after install. It was the electrical connector to the valve which was not plugged in properly and lost connection.
In your case it is either both connectors or, more likely, the other end of the wiring (single point of failure).
      05-16-2024, 01:28 AM   #1549
evilgrim
Drives: 440i
Thanks, was it a simple replug it fix for you?
      05-16-2024, 02:28 AM   #1550
Skyhigh
Skyhigh's Avatar
1908
Drives: BMW F36
It was a simple "push connector in until it clicks" solution, done in 4 seconds.
      05-16-2024, 01:24 PM   #1551
evilgrim
Drives: 440i
So the service advisor said it's normal behavior after the break-in period of the exhaust. The sound is much tuned down now. The valves only open when throttle in high rpm. Not like the stock exhaust that you can manually open the valve when changing to sport mode. They didn't bring the car in to take a look.
Does that sounds right?
      05-16-2024, 01:45 PM   #1552
Skyhigh
Skyhigh's Avatar
1908
Drives: BMW F36
Not at all!! Complete... and I mean COMPLETE BS!! They simply sent you back!
1. If anything, after the break-in period the exhaust gets even louder (not significantly, but some notice a development; I never did as it turned out one of my valves was closed for months)
2. The control of the valves is UNCHANGED from stock!! Meaning: In Comfort they open above 4000 RPM and close below that. In Sport and Sport+ - they open immediately after you hit the throttle for the first time and stay open until you shut down or go into Comfort / Eco-pro.
MPPSK does NOT change the control of the valves in any way! The only difference is now you have two valves instead of one (which are controlled in parallel, not individually).
Check your wiring. I bet you will find it disconnected somewhere - either at both valves or on the other end. Another option is that it got damaged and cut-off somewhere if it was not installed properly, but this is rather unlikely.
      05-17-2024, 12:36 AM   #1553
evilgrim
Drives: 440i
After spending all afternoon trying to get the valves open I finally went under to check the wires and bingo one of the wire is severely damaged. Will show up at the dealership tomorrow to address this with the service advisor.
Skyhigh1908.00
      05-17-2024, 12:55 AM   #1554
eff32fl
eff32fl's Avatar
1082
Drives: 2019 440i M Sport THP MPPSK
The valves don't always open all the way even in Sport/+ mode (during normal operation and with working valves). I use Bimmerlink to force open the valves. A hardware valve controller is a better option though.
      05-17-2024, 03:08 AM   #1555
Skyhigh
Skyhigh's Avatar
1908
Drives: BMW F36
They do. They should!
Unlike the G series, in the F series the valves are binary. Either open or closed. There is no middle-stage. You are not doing anything differently with BimmerLink than what you can achieve by switching in Sport. Only additional functionality is that you can open them in Comfort (even below 4000)…. You can actually achieve the same by hitting the DSC button too 😉not sure who would need that though.
      05-17-2024, 08:23 AM   #1556
MoeTE87
OHIO STATE
MoeTE87's Avatar
721
I know this might be unrelated but when I had my 2018 F30, I bought the MPPSK exhaust 2nd hand with very low miles and in great condition and I sourced the MPPSK tune from a gentleman over in Europe.
I had the exhaust installed at my friends shop and then had the tune installed at my local BMW dealer, all in the same day.
One thing I noticed at the time was, when ONLY the exhaust was installed, I was not impressed at all with it. Did not sound good.
Once I got the car back from BMW after getting the tune installed, WOW! Talk about a huge difference in sound! I couldn't stop smiling and was sooooo freakin pumped that my car sounded like that!
One thing to note...when we installed the exhaust and turned it on and let the car warm up before revving in comfort and sport/+ we did notice the first time we put the car in sport/+ the valves did not open..not until we blipped the throttle a few times and I remember not having any issues since when I had the car.
      05-17-2024, 10:38 AM   #1557
evilgrim
Drives: 440i
That's what I thought. My stock exhaust was able to open in Sport and I can hear the valve being open when I press sport. But every BMW worker I talked to said you can't control the valve with the driving mode button.
      05-17-2024, 03:41 PM   #1558
Skyhigh
Skyhigh's Avatar
1908
Drives: BMW F36
Tells you something about the BMW employees you have talked to.
      05-17-2024, 03:45 PM   #1559
evilgrim
Drives: 440i
One lady told me yesterday bmw don’t do tune. She think m performance power and sound kit is m sport package. 😫
f30post
