F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F30 N20 1/4 Mile Thread
Extreme Powerhouse
      07-25-2014, 05:37 PM   #67
K320
Puerto Rico
131
Drives: G01-X3 30i MSport
JB4 map2, ER Downpipe, 100Oct:
13.495 at 101mph
      08-14-2014, 07:46 PM   #68
trey100
trey100's Avatar
Drives: 2020 M2 Competition
2014 335 MSport xdrive 6MT Stock:
Made 5 runs. 13.5x at 103.xx was my best. Had 2 of those, 2 at 13.6x at 103.xx, and 1 13.9 at 103.xx (launched at too low an rpm). 60' times were 1.8x/1.9x. Worst was the 13.9 when my 60' was 2.0x seconds. Overall happy with those results for stock and 6mt. Trap speed never changed which seems reasonable. My last E90 335 6mt (rwd rather than xdrive) had a best of 13.6 but I wasn't consistent so a bunch of 13.9s-14.1s. I'm sure the 8AT would be better with the short gearing.
      08-15-2014, 04:02 PM   #69
mattssi
Drives: 2019 X3
I just use launch mode. Easy-P-Z
2021 ///M3
2019 X3
      08-15-2014, 09:43 PM   #70
K320
Puerto Rico
131
I use sport+ in s mode.
      11-12-2014, 12:12 AM   #71
MyFragileHalogen
Drives: '16 M4 6MT
Doesn't S mode shift at the redline? Isn't shifting around 5~5k better, if we look at dyno sheets and data logs?
      11-15-2014, 10:48 AM   #72
K320
Puerto Rico
131
I believe it is at redline.
In a few days i goona be back at the track so i can check.
      11-15-2014, 11:29 PM   #73
sirhawes
sirhawes's Avatar
Drives: '12 328i Imperial Blue
Considering gear ratios it's still faster to shift at lower horsepower in a lower gear
      11-16-2014, 01:29 AM   #74
MyFragileHalogen
Drives: '16 M4 6MT
Oops, typo. I meant 5000~ 5500 rpm. It seems that both torque in dyno curve and boost psi in JB4 logs die after 5000-5500 rpm.
      11-16-2014, 02:23 AM   #75
sirhawes
sirhawes's Avatar
You're right, but the engine will rev faster in a lower gear, so the slight drop in power is not worth shifting early for
      11-16-2014, 08:02 PM   #76
XenaBimmer
XenaBimmer's Avatar
Drives: '14 328i, '14 320i
My 328 8spd has BMS stage 1 and Injen cai, what should I expect in the 1/4 when I run?
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
      11-16-2014, 10:54 PM   #77
K320
Puerto Rico
131
If temp is around 80 maybe 13.7 o 13.8.
Colder temp 13.6
      11-17-2014, 05:56 PM   #78
XenaBimmer
XenaBimmer's Avatar
Colder temp 13.6
I was thinking 13.5 with a good 60ft, so that seems about right. I use to own a Cayman S PDK, and ran a 13.0@108, so was thinking this car wouldn't be to far off of that; around town, the 328 feels just as fast as that CS did.
      11-20-2014, 01:50 PM   #79
MyFragileHalogen
Drives: '16 M4 6MT
You were right. I observed better 0-60 times with S mode!!
In S mode, it shifts from 1st to 2nd at around 5.5k, and 2nd to 3rd at about 6.7k. With M mode it was not possible as limiter kicked in at around 6.5k.
      11-23-2014, 10:16 PM   #80
pr0lene
Drives: 328
We did drag racing yesterday here in Indonesia
My friend modified f30 320 (jb4 etc) did it in 14.157s (3rd place for 14s class)
my light mod SB chip+DP only hitting 13.9 for 328i (dis)
other n55 with jb4+wmi hit 12.5
temp maybe below 40C
[spoiler]
[/spoiler]
NB sorry for big picture i can't put it in spoiler
      11-30-2014, 02:13 PM   #81
M&M
M&M's Avatar
South Africa
113
Drives: Boosted Beemers!
We just ran our 320i to 13.5. Will post videos & results as soon as I can.
      11-30-2014, 04:14 PM   #82
XenaBimmer
XenaBimmer's Avatar
Wow!
What mods?
      12-18-2014, 08:54 PM   #83
mperformanceworks
Drives: f30 320 sport
I ran 14.6 with a 320i bad traction in DS mode not sport+. MAP5 with bad octane gas. Only Mods DP and JB4. Running stock runflats in bad weather. Car is a lot faster with high octane gas. Right now the fastest 320i runs 12s in Taiwan.
      03-31-2015, 11:00 AM   #84
xxxjecxxx
xxxjecxxx's Avatar
Drives: F30 335i M sport
2013 BMW 335i  [0.00]
2006 BMW 325i  [0.00]
What is the fastest 1/4 recorded so far for 328i?!
      03-31-2015, 11:03 AM   #85
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
Wow! That's rediculous. Linky?
      04-05-2015, 06:58 PM   #86
wolves
Drives: 2014 BMW 328i
Shit I need to see that
      04-24-2015, 02:03 PM   #87
mperformanceworks
OK using Same mods F30 320i limited traction just ran a 14.1 really bad gas map 5 so as M&M posted I have to agree on the 13.5s for modded 320i F30.
13s capable just with new tires and 95OCT (AKI) real gas not the crap I get here. Not fast by any standards...just wanted to see what it runs.
check vid
last 2 passes vs. N55s this is a new track so traction is not optimal.
About Taiwan they use upgraded turbo and water injection. N20s are popular there. I have seen the numbers and 12s is common. They are shooting for 11s now. Lots of broken axle shafts and blown motors so it is not like they are not pushing those cars to the limit. I believe there is one person already getting upgraded custom pistons for one FBO 320.
BTW have you guys checked out MANHART with their new reflash. Puts the N20s at 446Nm of torque way over the 420Nm of 328s with the same stage 1 reflash.
http://www.shop.manhart-performance....ormance-Kit_23
http://www.shop.manhart-performance....ormance-Kit_26
      04-30-2015, 10:35 PM   #88
XenaBimmer
XenaBimmer's Avatar
Ran a 13.6@101 in my 328 w/ BMS stage 1 even with a bad 2.1 60 foot. This was my first time ever taking this car down the track as well, and didn't get to do any other runs
I'm on the stock run flat tires and launched pretty easy brake torquing to 2k rpms.
Sub 13.5's should be do-able with more practice!
f30post
