10-30-2013, 08:51 AM | #45 | |
Rep 5,140
On xDrive it's important to keep the difference in front and rear diameter within 0.5% on a staggered setup! But since we discuss a square setup it doesn't matter. To me it just sounds like the dealer trying to sell a new set of winter tires. I checked OEM 16" (205/60-16) and OEM 20" (225/35-20) tires, the difference in overall diameter is above 2%. |
12-02-2013, 12:55 PM | #49 |
Rep 282
Would like to install on an F32 M-sport:
Front: 20x9 ET:35. Tire: 225/35 Rear: 20x10 ET:45. Tire: 255/30 Any issues I should look out for? Thank you for your help. Colin |
12-02-2013, 02:23 PM | #51 |
Rep 5,140
12-03-2013, 11:02 AM | #52 | |
Rep 282
02-09-2014, 11:00 AM | #53 |
Rep 198
want to install on my new F32 M sport:
19" M5 345 style wheel 345 Specs: Front: 19x9" ET32. tires ______? Rear: 19x10" ET34. tires_______? what tire size should i run for best fitment? possible? (fingers crossed). |
02-14-2014, 09:02 PM | #54 |
Rep 16
Anyone know what size winter tires and wheel i need on a 2014 335i m-performance car? Stock are the staggered 20" Can i get non-staggered 17" on it or 18"???
03-08-2014, 05:06 PM | #55 |
Rep 5
Would like to fit 20" style 361 on my F32 435d xDrive with the M Sport brakes
Front: 8Jx20 ET:36 225/35R20 (vs current 8Jx18 ET:34 225/45R18) Rear: 8.5Jx20 ET:47 255/30R20 (vs current 8.5Jx18 ET:47 255/40R18) Any issues I should look out for e.g. front spacers required / clearance / xDrive issues? bimmerposts wheel offset calculator says the new rears will have “the same clearance on the strut side, and the outside edge of the wheel will extend to the same point as the stock wheel” but the new fronts will have “2mm less clearance on the strut side, and the outside edge of the wheel will retract 2mm” Thanks in advance, Stephen |
04-02-2014, 12:39 PM | #60 |
Rep 1,805
19x8" ET36 225/40/R19 front / 19x8.5" ET47 255/35/R19 rear
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
04-15-2014, 12:10 PM | #62 | |
Rep 3,958
I'm thinking to buy another staggered OEM 400M setup and use: - (4) 18x8 all around for 225/45/18 winter tires - (4) 18x8.5 all around for (245 or 255)/x/18 summer tires The stance may look a bit weird, but hopefully some wheel spacers can correct it? |
06-05-2014, 08:49 AM | #63 |
Rep 143
Looking for 18" winter rims for a 335i Msport.
Found a nice set of used M3 rims that measure as follows: Front Wheels: 18" x 8" -- Bolt Pattern = 5x120mm. Offset = ET47 Rear Wheels: 18" x 9" -- Bolt Pattern = 5x120mm. Offset = ET26 Does anyone have a quick idea if these would fit, and what the best tire size would be? Thanks. |
08-04-2014, 09:34 AM | #64 |
Rep 76
I am planning on buying AG M359 19x9 et35 (front) and 19x10 et 38 (rear) with PSS 235/35/19 and 265/30/19. I currently have the stock 17 in wheels, will this work for me?
08-08-2014, 02:45 AM | #65 |
Rep 24
Hey guys will the style 313 wheels from a E90 fit my F30? Im also not too sure about the lugs and bore.
19x8 ET35 / 225/40R19 Fronts 19x9 ET39 / 255/35R19 Rears Its basically the same except that the rears are 15mm farther out. Thanks. Last edited by xshadowwolfx; 08-08-2014 at 03:12 AM.. |
08-09-2014, 07:19 AM | #66 |
Rep 5,140
