F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Reverse camera module location?
proTUNING Freaks
      05-06-2024, 08:48 AM   #1
bobman288
Drives: 2014 328i GT
Does anyone know where the reverse camera module is located? I’ve had the rear side panels removed and also taken out the carpet in back but nothing. Also checked under the passenger footwell up front.
      05-06-2024, 10:23 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
There's no specific reverse camera module. It uses the REM, rear electronics module, located in the right side of the trunk.
      05-06-2024, 01:45 PM   #3
dogballs
dogballs's Avatar
New Zealand
66
Drives: Bmw 435d Xdrive
2018 Honda CRF1000  [0.00]
  [0.00]
It’s in the Drivers side kick panel.
      05-06-2024, 03:07 PM   #4
Billfitz
Billfitz's Avatar
That's the FEM.
      05-06-2024, 06:36 PM   #5
dogballs
dogballs's Avatar
New Zealand
66
  [0.00]
retrofit instructions attached to aid finding what you're looking for..
File Type: pdf BMW EBA 361831 Rear View Camera Retrofit Instructions.pdf (428.8 KB, 28 views)
      05-07-2024, 12:58 PM   #6
chr15gb
Drives: 2014 F34 335i
I just retrofitted a reverse camera to my 2014 F34.
I can't for the life of me see a way of routing the cable from the tailgate into the cabin.
At the moment it is looped so not a great position but at least the camera works.
I can't find instructions for removing the trims and accessing the cars loom to get the cable through.
How do you get those funky instruction leaflets?
      05-07-2024, 03:58 PM   #7
Billfitz
Billfitz's Avatar
I installed one of these, with the camera mounted on the hatch right next to the OEM camera.
https://www.amazon.com/dp/B0811Q28N6...A2KR0J0CK34VOC
I ran the cable under the various trim pieces all the way to the rear view mirror that it attached to. There's no funky instruction leaflets, you have to figure it out, but it can be done.
      05-07-2024, 06:52 PM   #8
rlesko
Drives: F30 335i
2012 335i  [0.00]
Not true. Pre LCI models have TRSVC/reversing camera module is in the driver footwell. The FEM is in the passenger footwell (assuming LHD). I do believe LCI models eventually transitioned to ICAM style, which eliminates the need for a module and the camera feeds directly into the HU.
Source: I retrofitted reversing camera the OEM way.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
      05-07-2024, 09:49 PM   #9
Billfitz
Billfitz's Avatar
When I coded my rear camera functions it was done in the REM.
      05-08-2024, 05:10 AM   #10
Zheez
288
Drives: 320D (2015)
Depends what you're using. I've fitted camera emulator boxes which just required me to code the HU and the REM but if you're fitting the genuine BMW reverse camera hardware (pre-LCI) then you'll have the TRSVC module which also needs coding.
With an emulator there's no TRSVC to worry about and with an LCI car there is no separate module so it's ICAM instead of TRSVC.
As the retrofit guide linked above mentions, if the car is pre-LCI and it came with reverse camera from factory or has had the genuine BMW retrofit then the TRSVC module is located under the trim in the driver's footwell - there are different mounting brackets for LHD and RHD cars, so it will be on your driver's side regardless. Not the best picture and my car is RHD but you can see the silver module at an angle above the foam padding:
You can also see it here through the cutout I made when I was cutting a hole in my dash for the storage compartment:
      05-08-2024, 07:19 AM   #11
rlesko
Drives: F30 335i
2012 335i  [0.00]
Based on your above comment it seems you installed an aftermarket camera? So that would explain why.
      05-08-2024, 07:43 AM   #12
Billfitz
Billfitz's Avatar
No, this was with my OEM camera. Among the things I coded, all in REM, were:
REM 3203 V_SCHWELLE_2 werte = FF (default werte = 0F) The speed when it auto disables rear camera view (FF = 255 km/h)
REM 3203 D_SCHWELLE_2 werte = FF werte = 00 The distance when it auto disables rear camera view (default FF = 255 meters)
      05-08-2024, 12:47 PM   #13
rlesko
Drives: F30 335i
2012 335i  [0.00]
I have no idea what you installed, but even realOEM indicates a control module for a backup camera on a ‘15 F34.
https://www.realoem.com/bmw/enUS/sho...diagId=66_0291
It’s possible you installed an ICAM and also coded HU, though.
      05-08-2024, 02:17 PM   #14
Billfitz
Billfitz's Avatar
I didn't install anything. The camera came with the car. All I did was to code various options, all in REM. There were no other options.
      05-10-2024, 08:31 AM   #15
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
Originally Posted by Zheez View Post
... and with an LCI car there is no separate module so it's ICAM instead of TRSVC.
On the contrary, my 2017 LCI F34 has the rear camera module installed from the factory. Car is North American spec.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
f30post
