F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 dash rattle - fix in 5 minutes for free
proTUNING Freaks
      01-21-2020, 06:07 PM   #1
AtlantaDan
Drives: 2017 330i Msport Touring
2016 F30. Dash rattled over semi-rough surfaces and it was literally going to make me sell the car. I traced it down to first the external LCD display, then I thought it was the speaker. Removed them both and lined things with felt tape to no avail. Finally discovered that the rattle was coming from under the dash - between the LCD and the speaker. Further digging through the dash and through diagrams on RealOEM led me to think that I didn't want to tackle full removal of the dash to get it sorted.
Get a wire coat hanger. Put the hook in one hand and pull outwards on the bottom of the hanger - making it pretty much straight. On the non-hook end, put a slight bend in it upwards. Maybe 10 degrees. Grab ahold of the center decorative cover/vent below the screen and give it a tug. It will pop off. Slowly and carefully work it off to the passenger door. You can let it hang or prop it somewhere out of the way. You don't need to disconnect the wires going to the center part. This should take you about 10 seconds total.
Grab a roll of paper towels and your flattened hanger. Lean forward and give the dash a slight knock with the side of your fist, right on the top of the pass side, and you should hear the rattle behind the LCD clear as day. Looking at the diagram, there is nothing under there but the HVAC runners and some other plastic bits/shielding. I suspect that something in that space has warped or come lose over time and this is what we're going to fix.
Take 2 paper towels (-ish) in one section and start folding them. Half, then half, then half, then again. Keep the width - you're going for a wad that is as wide as the towel on the roll, about 6" deep, and about 1/4 thick. Now take that wad and bend it in half again and slide it into the space above the center AC vents. Don't go nuts - just get it snug.
Get your hanger, and using the non hooked end, wedge it between the folds of the most recent folding, and slowly start pushing the paper towels into the space above the vents and underneath and behind the LCD. There is a small cavity in there and that's what you are filling. Eyeball the length of the hanger you've pushed in to determine if you've hit the spot. Concurrently, keep knocking the dash with your fist and when you hit the right area, you will hear the rattle stop - or get lighter. On mine, I had to do this twice to get it to completely stop rattling. At no point should you feel any significant resistance - if you do - STOP. Also, you will not need to pack that stuff in there. You only need to put enough in to put some pressure on what is rattling and moving around.
Installation is the reverse of the process. Just be careful when knocking the center vents back into position. Otherwise, you can't really screw it up. I did mine a few months ago and have had zero issues since. And no rattles.
As with everything online - YMMV.
Hope this helps someone.
Gertsee51.00
Chaos236210.00
      01-21-2020, 10:36 PM   #2
Gertsee
Gertsee's Avatar
Drives: BMW 435i
This has been a very common and annoying issue which has also plagued my F36 thank you for posting this I will be trying this in the near future!
      01-22-2020, 08:31 AM   #3
amancuso
amancuso's Avatar
727
Drives: 330it, 428ix, 430i
On mine I get the rattle once in a while. Always thought it was coming from the rear-view mirror area. I supposed you could also use soft foam strips instead of paper towels.
2016 428ix, r, 2018 430iC, 2018 330it
      07-31-2020, 07:15 AM   #4
emfollin
Drives: 2015 335i M-sport
My entire center dash made noise from all the plastic trim used. I removed all trim pieces from the center, HVAC/radio, trim that goes from steering to passenger side, plastic piece with light in it below HVAC controls and the nav screen. I put electrical tape around all corners of everything. You have to pop the HVAC vents, HVAC controls and radio controls out of their surrounds. For the nav screen, I popped the plastic cover off the back after removing the two screws holding it and covered the back with electrical tape. Basically electrical tape everything. I also noticed the plastic covering the steering column squawked awfully when pushed. Removed it by prying the seam in the middle of both sides, taped the edges and the middle top where the plastic was rubbing a raised part of the steering column. I’d say I eliminated at least 90% of squeaks in dash. With all the plastic, not sure I could ever get to 100%.
      05-05-2024, 07:34 PM   #5
craigowens
Drives: 2015 BMW 335i
Adding to an old thread because it fixed my rattle and it is the best post I could find on my particular problem. However, I was not sure where exactly to push in the paper towels, as there was no photo in the original post.
I had the same rattle that seemed to be coming from the center of the dashboard, between the screen and the center speaker. I could not find its source even after disassembling most of the dashboard. I read this post and though it was a pretty amateur solution, but as a last resort I tried it. I jammed two shop paper towels in there with a long screwdriver. I located it right above the foam between the center vents as shown in the photo. I damaged the foam but the rattle seems to be gone, at least after my initial test drive.
f30post
