F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > N13 (F31) Rough idle(cold start) since a few days.
Extreme Powerhouse
      05-03-2024, 12:20 PM   #1
Doedelzak
Drives: BMW F31 316i
Since a few days my 316i (2013) is idling rough at cold starts. It fluctuates from 700 - 1200 rpm.
It stalled ones when letting go the clutch, and after restarting it gave a "Drivetrain" error.
I've attached the error codes that i got with Bimmerlink.
Anyone knows what this could be? Maybe a vacuum leak or something?
Id appreciate the help!
      05-06-2024, 04:16 AM   #2
Doedelzak
I've checked for vacuum leaks (optical) but could't find any by eye.
I have cleared the codes and drove about 100km with it. Yesterday i got the Drivetrain error again. But this time it only gave the Turbocharger coolant pump 20A608. Car still has a rough idle though.
- Could the auxiliary coolantpump be causing the rough idle? I think this is unlikeley.
- Should i have the auxiliary coolant pump replaced?
- Anyone has an idea what can cause the rough idle? Option's i have read are: Vacuumleaks and a leaking PCV membrame.
      05-08-2024, 06:10 AM   #3
Doedelzak
I have found the Vacuum issue, turnout that the Vacuum line to the PCV was snapped. I didnt saw this when i checked earlier. I have replaced the line and runs like a charm now.
The only issue i have now is the coolant pump fault code. I have ereased the code, maybe it had to do with vacuum leak somehow but i doubt it.
Lets see if it comes back
f30post
