F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Slow Pressure Leak on Single Tire - Unusual Pattern
proTUNING Freaks
      05-06-2024, 06:07 PM   #1
eleven11
eleven11's Avatar
Drives: -F85 X5M-
I'm curious if anyone has any thoughts on my single tire, slow pressure leak. I'm on PS4S, with plenty of rubber, and currently run 35 psi on all 4 tires.
Recently, I left my home and was alerted to the front left tire being at single digit PSI. I immediately filled it back to 35 psi, and carefully drove to my destination. I returned home after driving around 20 miles, without an issue, often watching the in cabin PSI meter (no drop). The next morning, as expected, it dropped. However, it was only 25 psi. Again, I reinflated to 35 psi, and drove around 20 miles. Since that time, it has not budged, staying at 35 psi.
I'm planning to have it inspected, and likely patched. However, I'm trying to understand this odd pattern (i.e. holding air now). All other tires are normal. Any thoughts or ideas? Thanks.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      05-06-2024, 06:18 PM   #2
Mkesler75
Drives: BMW f34
Likley just the position the tire is in when parked. Putting more or less pressure on whatever is puncturing your tire
eleven11376.00
      05-06-2024, 06:49 PM   #3
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Thanks. I considered this possibility, which is likely the answer.
2017 X5M - Current
      05-08-2024, 06:11 PM   #4
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Update:
So the tire hasn't dropped any more than 2psi, despite several days and miles of driving. Still odd to me that it originally dropped to 6psi in under 24 hours, but hasn't repeated this severe drop since that time.
2017 X5M - Current
      05-11-2024, 05:39 PM   #5
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Update:
I had a tire shop inspect the tire yesterday. They were unable to identify any obvious leaks. However, it was noted that the valve stem had some corrosion. The valve stem was replaced, and everything seems to be holding stable. So, an interesting leak pattern to share. Unless anything changes, I'll conclude these updates.
2017 X5M - Current
f30post
