F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > UK - Off Topic > Handy automotive-related gizmos…
Extreme Powerhouse
      01-13-2024, 05:47 PM   #45
XAlp
Drives: Volvo XC90 T6
I used to have something like these for my F31.
Having crocked my back a couple of times changing wheels I was happy with them.
https://www.ebay.co.uk/itm/360586790184
cramsnik394.50
DaveA1885.00
Pond1911.50
      01-14-2024, 04:07 AM   #46
cramsnik
Crustacean denier
cramsnik's Avatar
395
Drives: M3LR
These are really handy, forgot I had some... current car has studs so redundant right now.
danb19791988.00
      04-18-2024, 03:55 AM   #47
cramsnik
Crustacean denier
cramsnik's Avatar
395
Drives: M3LR
Originally Posted by cramsnik View Post
Got a flat a few months back and was let down by a can of Tyre Weld and ended up having to be recovered.
Turns out these tubes/cans of slime are a bit hit and miss, had a google and saw these type of things suggested so for less than a tenner I got this -
https://www.amazon.co.uk/gp/product/...e?ie=UTF8&th=1
Thankfully not had cause to use them yet but for a couple of quid worth chucking in the boot, you never know they could work and be the difference between being able to carry on under your own steam.
Had the misfortune of a 3" Hex bolt go right through the centre of a rear tyre last night whilst up in Manchester. Pleased to report after much swearing I managed to get the bolt out and plugged the hole with the above kit. Made the difference between getting home under my own steam and having the car recovered on a low loader .. which was what happened last time around.
Ennoch2260.00
      04-18-2024, 12:16 PM   #48
TodmordenLad
2891
Drives: Audi A4 Avant
Hardly a gizmo but a thumbs up from me for Sonax Xtreme Brilliant Shine Detailler, which I use after washng the car. Quick and easy to apply if you like a smart but not too shiny finish but can't be a*sed to spend ££ on products and hours on the job!!
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
M80145.00
      04-18-2024, 01:19 PM   #49
AlwynMike
337
Drives: F36 440i GC.
But does the "Brilliant Shine Detailer" translate as "Restore With Brillo"??
      04-18-2024, 01:22 PM   #50
TodmordenLad
2891
Haha - no, it's gentle stuff 😊
      04-18-2024, 06:36 PM   #51
Scoobyd
Scoobyd's Avatar
1971
Drives: E46 330ci Sport / Macan GTS
BSD is great stuff. Been using it for years and always well stocked up on it. Smells nice too!
M80145.00
      04-19-2024, 01:57 AM   #52
M80
Drives: F31 330i Shadow Edition
Sonax is my go-to product also.
Primarily 'cos I'm a lazy bugger and more often than not can't be arsed with 'proper' wax.
Scoobyd1970.50
      04-19-2024, 02:53 AM   #53
GOF_430d
Drives: 430d convertible
Thanks for the recommendation as I've run out of Demon Shine so I'll give the Sonax stuff a try. Amazon here I come & now in my basket.
      04-29-2024, 03:43 AM   #54
gac
51
Drives: BMW F31 335d
2015 BMW 335d  [0.00]
Originally Posted by danb1979 View Post
This:
https://www.amazon.co.uk/FreeTec-Man...s%2C112&sr=8-8
Makes life so much easier when it comes to oil changes
Thanks for the link, just ordered one. I only have a 5L Pela which has never been a problem as I've never owned a big six-cylinder but it makes it hard to tell how much you've extracted from the BMW because you get to the 5L mark and then have to empty it. Which coats the entire inside of the sphere with black oil so good luck seeing how much you've pulled out on the second go...I actually ended up slightly overfilling it due to that and then having to Pela out some of the brand new oil before driving, so buying this bigger pump seems like a good idea for next time.
For anyone else considering, there's a 15% voucher applied at checkout for the next couple of days, making it ~£53
danb19791988.00
      04-29-2024, 02:37 PM   #55
danb1979
Idiotic lifter of heavy stones...
danb1979's Avatar
1988
Drives: 2015 F31 325D M Sport touring
It's been a superb tool; I've got a 5L sphere one also and like you; trying to empty a 3.0l straight 6 petrol or diesel, it just gets messy with having to stop the flow to empty etc...
I have extended the drain line as it's not long enough to leave the pump on the floor and reach to the bottom of the sump etc
I used this: https://www.ebay.co.uk/itm/163863949...r=463442863273
It fits over one of the drain lines that comes with the pump and onto the pump connection perfectly
Means you can have it set like this then:
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
      04-29-2024, 02:42 PM   #56
gac
51
Do you remember which size? The extractor comes with 4mm, 6mm and 10mm - I'm assuming 10mm will give the quickest flow but does it end up being too thick to fit properly in the dipstick hole?
danb19791988.00
      04-30-2024, 03:10 AM   #57
j.s.
Drives: F36
Anyone used these on a petrol where there is no dipstick? How would that work?
      04-30-2024, 03:32 AM   #58
danb1979
danb1979's Avatar
1988
As per the link; ID is 6mm, that's what connects to them tightly and fits down the tube perfectly
gac51.00
      04-30-2024, 03:33 AM   #59
gac
51
Ahh, gotcha, I just assumed 6mm was the default size on the listing, I didn't realise you could deep link to a specific SKU on eBay. I'll get a length of that ordered too, ta.
danb19791988.00
      04-30-2024, 03:34 AM   #60
gac
51
It wouldn't you're stuck with doing oil changes the traditional way.
j.s.48.50
      04-30-2024, 03:36 AM   #61
danb1979
danb1979's Avatar
1988
You can't; the whole purpose is to use the dipstick tube rather than crawling underneath
j.s.48.50
f30post
